Lund Flex Fuel AFR
v8440
AL
2016 gt
Who, me? Yes, I did. It's getting worked on.
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
Never had any E85 in it. Just loaded the tune for the first time after installing the intake last night. It has Sunoco 93 in it.
Yeah that's not normal. Default stoich should be 14.0-14.1 normally at E-10 so it should have defaulted at 14.0-14.1
venumous
venumous
PA
16' Procharged GT
Did you data log your tune yet, and send it in to be revised? Also what size injectors are you using with the new manifold?
I just logged it and am sending it in. Lund talked me into using the stock injectors for this setup and assured me it is fine.
Terminator2
Spring Hill Florida
David
The stock injectors should be fine unless you are running E-85 on a high flow manifold and revving to 7600 (some are still ok if PE lambda is not on the richer side)
venumous
venumous
PA
16' Procharged GT
I plan on revving to 7800 and it will be rare that I run E85 but it will be done.
beefcake
Bethel
2018 Ford Mustang
lund tunes for lambda, a/f will very based on different stoichs of fuel.
unless something is way off in the mechanics of the car ,especially n/a, the car will be be the exact stoich lund wants
venumous
venumous
PA
16' Procharged GT
Got a revised tune this morning from Greg at Lund. He said he adjusted it for the intake, which was off a bit and some other changes. I'll load it up and relog and see where it gets me.
Niz55
Us
17 GT350
I am having the same issue. At wot I am at 9afr to 9.5 Afr. I am running gt350 manifold and 47lbs injectors with ff tune. It pulls very nice but 9.0 is very rich.
16s550
Bay area
2016 GT M6 performance pack, whipple charged
Subd
venumous
venumous
PA
16' Procharged GT
Not sure there is anything to sub for. I think it's in the way the Lund flex fuel tune is using the fuel system to calculate ethanol content creating a calculated AFR that is not actual. I got better MPG on 93 as you would expect and the car always ran great.
16s550
Bay area
O ok.thought u seen a few guys in here have afr being to rich when running 93 on flex fuel tune. Wanted to sub just in case I get same problem. I have my tune being written at Lund and they will ship with guage. Gonna install it with 91 in the tank than switch to flex soin as its low enough.
Niz55
Us
17 GT350
I thought you can run around 12afr with e85?
i paid 1.97 a gallon last night. gas mileage was instantly shitty as expected.
16s550
Bay area
The lower price in fuel evens out for the shitty mpg dosnt it?
RubyRedBoost
Traded EB old name New GT
Fort Worth
Josh
2015 Guard GT with PP
10-10.4 afr at idle, 8ish WOT. Just watch lambda 1 and 2. They should be around 1.0 at idle and .85 WOT.
