Loud clicking under acceleration
TorqueMan
St. Jacob, IL
2017 EcoBoost Premium
Its literally your spark plugs, not your tune. :headbonk:
I don't get this. There are no moving parts on a spark plug. The only clicking noise I've ever heard from a plug is electrical arcing, like when a plug lead is loose, or if the plug's insulator is cracked. That clicking is nowhere near loud enough to hear in the cabin under acceleration. Further, in either one of those cases you'll get a misfire since you'll get insufficient spark in the combustion chamber. Can you elaborate on what you mean?
clubamericalara
OKC
www.youtube.com
2015 Ecoboost
I wont sit here and try to convince you that its the plugs, but i invite you to do some digging in this forum. search "clicking" and you will see that plugs can be the fix, not always but theres a possiblity. The ecoboost from the factory has frequent cases of plugs being unproperly gapped. literally took me 30 minutes to check them and replace them.
TorqueMan
St. Jacob, IL
I'm not asking you to convince me it's the plugs. I'm asking you to explain the mechanism where a faulty or improperly gapped plug can make a clicking sound. If you're saying a bad plug can cause engine knock (detonation) I understand that, but that's not the same thing as saying a plug is making a noise.
clubamericalara
OKC
www.youtube.com
2015 Ecoboost
Im not a mechanic so I will not explain the mechanical aspects, i'll tell you however i experienced heavy clicking especially under throttle.
this was fixed after replacing the plugs. the factory spark plugs were anywhere from .20 to .33.
it takes 30 minutes to check. you do you though :cheers:
TorqueMan
St. Jacob, IL
Dude(ette), I'm not trying to put you on the spot, I'm trying to understand the problem. If I have a problem I want to understand what's happening before I start making repairs. Not that I don't enjoy mucking about under the hood, mind you, but replacing/repairing things because it MIGHT fix a problem seems like a waste of time. :frusty:
But that's just me being me.
CustomS550
South Carolina
2016 EB Mustang
Once plug gas is out of the question, Could this be a case of faulty / sticking injector(s)?
Datalux
SoCal
2016 EcoBoost, Premium, Auto, PP
Did the frequency increase with speed and/or RPM?
Not sure as it was at the top of first gear when I was expecting it to shift into second and as soon as I heard it I came off the throttle.
Can you feel it?
I did not feel it. Well I take that back...there was an immediate tension in my sphincter.
How loud?
Loud enough to hear over high rev and an audio book.
Did you notice any decrease in performance?
It did seem to dog or at least level off but I let off pretty quickly at which point it stopped.
Consider recording data next time it happens
I would prefer not to recreate it or vent my block but I did put my AP back in and it will have data if it happens again.
Datalux
SoCal
check your spark plugs, mine used to make that clicking noise under full throttle until i replaced them.
Really?? I'm running Denso ITV22's which were gaped correctly. I can't imagine anything relating to a plug making that noise unless it broke off and was banging around in the cylinder. :eek: It's only done it once so far and I have had it at full throttle several times since, just not in first gear.
Brian V
USA Retired
Native Earthling
2015ecoboost premium 201A Nav Sec Race Red
Throw some redline in your fuel tank and be done.
PRG3k
Orlando
Turbo
Could just be the direct injection clacking.
Elgyn
Vancouver, Canada
2016 ecoboost, MT, DIB, Premium, PP
the catalytic could be crack
Turbong
SoCal
2016 RR EB 6MT PP Recaros
