Condor1970
- Oct 4, 2018
- Port Orchard WA
- 2018 Mustang GT
I wasn't sure if I should even bother posting this, but one problem my GT has had, other than the infamous "tick", is the E-brake handle tension was very loose from the day I got it. You could bump the handle upward and before it would even ratchet, the light would come on. It would just flop up and down a good 2" without any engagement. There used to be a barrel adjustment underneath in front of the cable splitter just above the resonator, but I think in the new 2018's that adjustment is now located inside the center console. They tore it apart, adjusted it in an hour, and it was done.
Just thought I'd toss that out there for anyone with the same issue. It may be something you can fix fairly easily on your own, if you don't want to drag it into the service dept.
