liquid noises in '17 gt pp.
robvish
Del Rio
Robert
2017 Mustang Gt pp
when I turn on the car I can hear like some type of liquid moving around sounds like from behind the glove box. anyone have any idea as to what it could be?
sk47
North Eastern TN
Jeff
Hello; two notions. First is the drain for the AC condensate is plugged up. Not sure on a mustang but usually a tube which exits under the car. Get the car up high enough so you can safely be under the car. Poke gently into the hose with something to loosen up the junk.
The other notion is the area in front of the windshield where the wiper motor is located. I call it a cowl. This area is sort of like a tray. The area also usually feeds air into the vents- heater-AC box. I have seen leaves and other debris clog up the drain for this area. Drain likely to be similar to the AC drain (Might be one drain for both) Same sort of fix, which is to clear debris.
KingKona
Virginia
Shlomo
2019 GT
Water in a door?
Linkster1666
AZ
Link
2019 Mustang GT Premium Orange Fury PP1 A10 401A 3:55
Don't like even thinking of it.
Heater core leak? You park car, car leaks a little fluid into the passenger side floor, start car, leak fluid replaced, gurgle gurgle. rinse repeat
ORRadtech
Atlanta, Georgia
My first two thoughts are refrigerant equalizing in the evaporator or coolant in the heater core.
