Lethal performance turbo kit
mbreinin
New Orleans, Booziana.
mike
2015 EcoBoost Premium.
Nice!! Keep it stock until something fails... Really curious to see what lets go
first!
My guess is a rod breaks, windowing the block. But, you never know. Either way, this is damn impressive. 42 pounds of boost on a stock engine. :headbonk:
Antyoo
Los Angeles
2014 Evo X GSR
When did the eco handle 42psi on stock internals?
maybe it is 42psi absolute pressure(including atmospheric pressure) and the relative pressure would then be ~27-28psi
or they are actually running 42psi:eyebulge:
very impressive run either way!
Z_Rocks
S.W. Fla, USA
Import
Track results will get better, that's for sure. But to clarify, stock motor from cam cover to oil pan and using MS109 fuel. We are testing our auxiliary fuel system that uses the CP-e fuel bar and a micro-squirt computer to control the second set of injectors, that's how we made that power, it's also only utilized once boost comes in. We'll make this available to you guys later.
Derek, what do you think the cost of "auxiliary fuel system" will be roughly?
And how much boost is safe with just a BAP?
higdominator
Central Oklahoma
2016 GT PPP
About $1000 at least. BAP not needed, even at E85 volume numbers. I'm currently running the CP-e rail and Adam is working on the E85 tuning.
Derek@Lethal
Wellington, FL
Derek
2012 Mustang GT 300A w/ Brembo's
I have no pricing on the system right now and we did not test any BAP's so no data to share. We maxed the stock fuel system at 427rwhp/445rwtq.
