Knock at +10 and light throttle. Uh oh.
TooSoonJunior
Southern CT
2015 Mustang GT PP M6
So how exactly do you open with that in regards to the wife?
Asking for a friend.
LOL I think he means it is easier to explain you need a new motor once it is hurt or blown, but explaining you want to yank the motor out when it is running perfectly fine sometimes raises an eyebrow.
Crackerjack17
Crackerjack17
WV/Maryland
2017 GT PP
Exactly. Kinda like having a girlfriend when your relationship with your wife is ok. Easier to explain if your already broke up. Hahahhaa
Crackerjack17
Crackerjack17
WV/Maryland
2017 GT PP
I bought a $10 boroscope camera off ebay. I looked at the low compression cylinders 7 and 8. And looked around in 1 and 5. They all look the same. A decent amount of carbon deposits, mostly to the sides of the center section. Valve pocket areas have even coating. Cylinder walls look good. I can see some light marks running vertical but they look the same as the good cylinders. I can't get it turn turn around good enough to look at the head side. I'll have to rig up a little string or tape to pull the camera backwards.
dubster99
Nor*Cal
2015 Ingot Silver GT PP
I need to get one of those just for fun. But yeah, get a leakdown done, or if you have a compressor, get or build a leakdown tester.
venumous
PA
16' Procharged GT
Hope you get her figured out with minimal damage. Your post made me paranoid with the knock I got on return system before reverting to old setup. Dry test on mildly warm motor was 210, 208, 210, 210, 205, 207, 205, 205. New tune being scheduled for AED.
Tommy V
Brookly park Md
Tommy
Those numbers look great.
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
OP sorry for your loss.
But if I am reading this correct Procharger are saying that any car running FI on a stock engine will create too much heat if WOT is maintained for more than 1/4 mile?
Is that true?
If the case then surely peoples engines would be dropping left, right and centre?
Makes no sense to me, my mate has a Whipple, around 700WHP, Lund tuned, stock engine (OPG done) and its being WOT and ran upto towards 200mph several times. But based on what Procharger guy is saying thats enough to kill the engine, true?
Or am I just reading this wrong?
Crackerjack17
Crackerjack17
WV/Maryland
2017 GT PP
I think what he is saying is... when you push these stock engines hard, you are generating a ton of heat for sustained amounts of time, which can be detrimental depending on many factors. One of them being tight ring gaps.
Gibbo205
UK
I've got a few mates who own these cars in Germany and they regular sit at 150mph plus for several minutes at a time, no engine issues for them. :)
An engine should be able to sit on a bench and operate for hours and maximum RPM without failure which the Coyote in stock form is capable off.
If FI is shortening their life so much, then to me going FI is way too risky unless your gonna spend the money on building the motor, might as well stay NA and safe.
mustang1
Dallas, TX
2016 Mustang GT
I think he was saying the Coyote is designed for NA and if you FI the stock engine, there is a little risk, as heat can build on the pistons faster than will register as CHT that gets monitored in the tune. Those built with tighter ring gaps being vulnerable.
There isn't many of these types of threads, but you have MMR advertising a cylinder 8 cooling mod. Implying that cylinder 8 runs a little hotter than normal.
Killswitch16GT
GA
2018 GTPP
Did you ever find out the cause? I've been chasing what i thought was false knock and now im worried. I have similar symptoms with knock up to +9 cruising light load, but get -4* at wot.
ProChargerTECH
Gold Sponsor
Boostville
2015 Mustang(s)
Is that true?
I have taken apart MANY of these engines for friends that are upgrading.
Some have pretty decent ring gaps stock (some even up to 18)
Others have had as tight as 8!!!
If anyone thinks a motor with a ring gap that tight will survive a pull to 200 MPH with 700+hp, they are a little cray cray as the internet kids say.
These motors are amazing but do have a variation to them.
Just because "your mates is fine" doesn't mean yours will be.
Anyone is free to do what they want.
Im just being honest saying that its no different then going to the casino and betting on "black" it might work out, it might not. And unless you been inside your motor, you have no idea knowing.
Storm728
South oc, ca
2019 gt
this has me concerned now :headbonk:
ProChargerTECH
Gold Sponsor
Boostville
2015 Mustang(s)
The majority I have seen have been in the 12-15 range.
Which is pretty normal for an "emissions motor"
(remember these new S550's are LV3 emissions)
However in a motor filled with pistons at 15, is where (2) slugs were 8!
So ya, thank goodness he was upgrading.
At a normal boost level, and normal 1/8th mile and 1/4 mile runs.
I know I personally have NO worries at all.
But those long 200mph pulls put a LOT of heat into the piston, and thats when trouble can start. I don't know many people that try to make runs like that, so really 99% of my friends never worry about it.
