You described my problem better than I could. The sound comes and goes which makes the dealer's ability to find it even harder. I have been to the dealer no lie roughly 5-6 problems for this issue. I've had my passenger side door molding replaced and side rocker refastened with no luck. If your dealer winds up finding a fix, would you mind letting me know what they did so I don't go batshit crazy?And here I was thinking I was going nuts.
My 19 passenger side rattles. It’s definitely a metallic rattle sound...almost like a click. It doesn’t do it all the time either. I had my girlfriend pushing and pulling on the panel while she was sitting there to see if she could isolate the sounds and no luck.
I’ll take it into Ford eventually for it...once it puts me on tilt enough and I lose my shit.
A two month old car rattling annoys me.
Good idea on the heatshield.You described my problem better than I could. The sound comes and goes which makes the dealer's ability to find it even harder. I have been to the dealer no lie roughly 5-6 problems for this issue. I've had my passenger side door molding replaced and side rocker refastened with no luck. If your dealer winds up finding a fix, would you mind letting me know what they did so I don't go batshit crazy?
Oh, and I am starting to think the sound is coming from outside the car. I can hear it start when the car rolls forward in first gear. The sound is certainly a metallic click. I know there is a headshield in that area that runs along the midpipe that could be hitting something. Then again, who knows.
Whatever it is, I'm thinking it may be temperature related. I don't hear it early in the morning when I'm driving to work, but I will hear it on my way home. I keep my car in the garage overnight and it sits out in an open lot when I'm at work. The dealer dissembled the body control module behind the kick panel and put a foam pad between it and the metal bracket which didn't help. I've also ridden with the kick panel off and didn't see anything that is loose and would make a clicking noise.Good idea on the heatshield.
I definitely will let you know if they find something. I haven't heard it since last weekend but I only drove it twice this week. The crazy thing is that it isn't constant nor does it do it all the time when I hit bumps, which you think it would if something was loose.
