Rear passenger seat panel rattle mystery fix
Discussion in 'Issues, Repairs, Warranty, TSB, Recalls' started by invaliduser, Dec 14, 2016.
  1. invaliduser
    invaliduser Well-Known Member
    Vehicle(s):
    2016 Mustang GT Convertible PP
    Feb 9, 2016
    Boston, MA
    165
    I found a rattle in the driver side rear seat area.
    [ame]
    If it sounds metallic it might be this. Certain vibrations would make it rattle and with my new mach thunder exhaust at certain rpms it will rattle too.
    A flap of the body panel isn't tight or something and it vibrates. The video points it out.
    I spent about an hour trying to figure it out. I ended up settling with gaffers tape instead and it worked. Trying to wedge your hand in that little hole and trying to shove a piece of foam under that flappy part of the panel is pretty hard.
    The other risk was I didn't want to drop anything down the abyss there to vibrate so whatever I used must be soft.
    I don't know if the convertible is different than the coupe but it's probably more accessible with a convertible. No trim panels need to be removed either. I had mine open because I thought I was chasing something else.
    I had to chase it down so hope this helps someone.
    CoolRod and Omega like this.
  2. jbanh100
    jbanh100 Well-Known Member
    First Name:
    Jackie
    Vehicle(s):
    2019 Mustang GT Premium
    Jun 4, 2019
    Houston
    54
    sorry to bring back dead thread. glad this fixed it for you but this might be my issue. sometimes when I accelerate it buzzes and it's so annoying probably cause of my exhaust. can you show me exactly where this is? I'm trying to comprehend where it is, but my brain is a little slow right now cause of work. Thanks! this may help a ton
  3. OP
    invaliduser
    Vehicle(s):
    Feb 9, 2016
    Boston, MA
    165
    Do you have a convertible? Is it in the driver side rear area?
    jbanh100 likes this.
  4. jbanh100
    First Name:
    Jackie
    Vehicle(s):
    Jun 4, 2019
    Houston
    54
    I have a coupe unfortunately. When I'm sitting in the driver side area I hear it in the passenger side, but if I lean back and accelerate with my head toward the rear seat I can hear it back there. Basically I looked like an idiot driving haha.
    I've already sealed all loose clips in both doors for other rattles so it can't be the door and pillars also.
    Only thing left would be this and under the car.
  5. OP
    invaliduser
    Vehicle(s):
    Feb 9, 2016
    Boston, MA
    165
    You'll need someone to sit back there and find it. It was easy for me to get at my problem after someone confirmed it was coming from where I thought it was.
    Being a convertible meant I could just open the top and have access from above down the hole. You'd have to take out the side plastic next to the passenger to get at what I described.
  6. jbanh100
    First Name:
    Jackie
    Vehicle(s):
    Jun 4, 2019
    Houston
    54
    Darn figured that would be the case. Where exactly is this location though? What you're describing. Is it the side of the rear seat on a coupe?
  7. OP
    invaliduser
    Vehicle(s):
    Feb 9, 2016
    Boston, MA
    165
    If you were sitting in the back seat it would be where your shoulder is think of the top of the quarter panel where the convertible top goes into.
Loading...
Share This Page
