Key fob replacement
Lakeland-GT
between IN & FL
SErik
2015 Mustang GT PP Race Red
Another dealer quoted key with smart fob (for Mustang manual trans) @ $208.75. without dealer programming
Lakeland-GT
between IN & FL
SErik
Use the FCC ID from your current key fob remotes to find compatible Ford remotes on eBay.
I'm doing that and will report back if it worked.
Lakeland-GT
between IN & FL
SErik
It worked.
I programmed my $45 eBay key today. No problems. Beats dealer prices. Doesn't come with a metal key thats cut though. And the logo on the key is a Ford logo not a Mustang logo. Other than that the key is exactly the same.
I followed the instructions from the car's manual. One note: when you get to the step in the programming process where you use the new key and push your car's start button, wait, because nothing will happen for a few seconds, then after a few seconds the car and key will initialize.
In other words, when you hit start with your two current keys, there is no lag or wait time, but the new un-programmed key takes a couple of seconds (no more than 5 seconds) when you follow the instructions in your manual exactly as written.
RoadDog
NC
Mustang GT
I'm in need of a 2nd spare key, anyone here know if a key for another model 2015 Ford (Fusion) will work IF the FCC ID is identical to the one I have??
Thanks in advance!
TractorJen
Wa
2015 Mustang GT Premium
Does anyone know if it is possible to program a fob if you only have one of the original remotes? Instructions ask for both.
ktp1598
Mount Washington, Ky
Bobby
2019 Kona Blue California Special
I'm sure a dealer can do it but that's pricey. I've not heard of an alternative for 1 keyfob programming.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Is one of the takeaways from this thread to purchase a 3rd key?
Because it is bad if you lose one of your two as-delivered keys?
Ecoboosted
A state in the South East of the US
18' Mustang GT, 19' Road Glide
I had to have my company Escape key replaced and it cost $225 for the key and $50 to program it. Hopefully the Mustang is cheaper.
paul123
'16 Mustang GT
I probably should get a third key fob. I currently have one setup as a MyKey, with 80mph speed limiter, and I read somewhere if the master is lost, or malfunctions, it will cause a headache.
brandonsmash
SMASH!
Phoenix, AZ, USA
2015 GT - PP
I picked up a $65 key on eBay. There are tons of keys for the automatic with the remote start feature, but few for the manual without it; I matched the FCC ID to a fob I found and even though it doesn't have the pony on the back it works just fine.
Way, way better than losing a key and being up sh*t creek.
HoosierDaddy
Randy
That could be a bad thing because it means anyone (like a valet) could make a spare if they had access to one key
ktp1598
Bobby
I had to have both keys to program a third. Really easy to do though.
nbad
Canada
n/a
Can you please point me to these instructions?
Has anyone had success programming a new key without both original keys?
OracleHCR
Otis
2018 Lightning Blue GT Premium PP1, Mag, AE
Go to owner.ford.com for the instructions. You will need two keys to program a third key though.
