Just got forscan need some ideals
Murd3r3d_237
Ohio
2015 mustang
I just got my forscan to add a couple things to my gt.
Before I start I would like to say yes I know they have a spread sheet. However it does not list everything you can add/do.
For example on the spreadsheet it doesn’t mention the boost gauge add on.
My question actually is what are some things you guys have added that you really like that you put on your car?
Murd3r3d_237
Murd3r3d_237
Ohio
2015 mustang
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
It’s complicated to find all the things that can be done since it’s not all in one place, and the people that have done them may not be the best at describing what they have done. Also, I think most of the research on all of this comes from the F150 groups, so while alot will translate over to the mustang easily, some will not work at all.
There are a few common ones that you will see pop up over and over. For me, there was not a lot that I wanted changed but I did try a few things out. I have the 9 speaker audio system so I did the EQ disable mod. I also changed to the Ford Performance splash screen and shutdown screen (I intend to modify these further and also the theme of Sync3 outside of forscan in the future - but that’s another topic all together). Lastly, I set my running lights to use the front turn signals as supposed to the low beams or accent lights (accent lights are still on, just like 50% bright). I just kinda poked around in the spreadsheets and the forum posts and even forscan itself (it has preset changes that can be applied for SOME things).
Murd3r3d_237
Murd3r3d_237
Ohio
2015 mustang
I have the stupid phenix radio and it isn’t very loud at all, do you know if that would help my situation ?
Murd3r3d_237
Murd3r3d_237
Ohio
2015 mustang
Curious how this goes for OP as a forscan newbie so I can decide to get my feet wet or not haha.
Everything has been super easy to do so far, boost gauge, fog lights, double honk disabled. All easy
