JLT or Roush CAI?
scgamecock
South Carolina
Wade
2019 Mustang GT Premium
Which is the better choice for a 2019 GT? It looks like the Roush is better enclosed to keep engine heat out but the JLT seems to be the more popular choice.
Do they both need to be paired with a tune?
Thanks
Wade
Zelek
Hutto, TX
2021 Mustang Mach 1
Yes, both do need a tune. I would stick with your stock intake though and tune it with a drop in filter. Best bang for the buck. That intake is already rather large on the 18+ and you aren't going to see much of a gain aside from it.
AZ18yote
Arizona
Bryan
Add a drop in and call it a day. Spend the $ you just saved on the cai on a flex or e85 tune and get alot more for your $.
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
We've been using JLT intakes on all of the Lethal builds for many years with great results. Roush is also a very nice intake. Just comes down to personal preference on which one you like the looks of the most. You'll need a tune for either of them.
We offer both intakes packaged along with devices and custom tunes from the top calibrators in the industry and you save by purchasing it as a package as opposed to purchasing each part individually.
Give us a call if you have any questions and we'll be glad to assist you.
561-753-8105.
https://www.lethalperformance.com/shop-now/vehicle-selector/ford-mustang-v8-gt/2018-2019-ford-mustang-gt-coyote/power-packages
luv2drum1
Anaheim, California, United States
Albert
I agree with the individuals who stated keep the stock airbox and replace the stock air filter with a washable panel filter (i.e. Airaid, AFE or AEM). If you are heart set on obtaining an aftermarket intake for the looks under the hood, then either the JLT or Roush is a good choice. Although, the Roush does not require a custom tune according to Roush's website. Honestly, a custom tune will make the biggest difference with regards to driveability and performance.
Zelek
Hutto, TX
2021 Mustang Mach 1
The reason I am using a 2018 version of the JLT is because the Steeda didn't work well with the Flex Fuel tune and the 18 JLT fits well to the 18 manifold while having a 120MM tube. I do however have a stock 2018 intake that I can use and I'm highly tempted to get a drop in filter and do that, but I'll see how the JLT handles the summer heat. So far so good with it.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
I have the Roush on my '15 and chose it for the near-OEM look and fit. The JLT is, um, less than OEM looking and fitting but functional (had one on my GT500). The Roush uses a MAF insert for a no-tune situation, or you remove it and tune. Zero complaints with my Roush CAI.
Based on what I've read on the board though, the OEM airbox on the '18-up cars is a decent piece with a drop-in filter as others have mentioned here....
EVL-S550
Northern VA
Thanks
Wade
Don't need a tune for the Roush if you run the insert. That said, I felt like it gave me loss of low end torque when I ran it. Went back to stock with a see drop in dry filter.
Smokey613
Redneck Riviera
www.facebook.com
David
2015 Mustang GT Premium Convertible Race Red
Will a 2018 OEM air intake fit a 15-17 and if so, is there any benefit? Sorry for the noob question but I am still learning about these Mustangs.
Zelek
Hutto, TX
2021 Mustang Mach 1
Will a 2018 OEM air intake fit a 15-17 and if so, is there any benefit? Sorry for the nube question but I am still learning about these Mustangs.
Yes, it will fit but you will probably need a tune due to the tube size being bigger. Haven't tested it myself but it does fit.
CoopDAWg70
Malvern, Arkansas
Kevin
19 Mustang GT, 98 Dodge Durango, 11 Harley Chopper
Thanks
Wade
The ROUSH CAI does “not” require a tune. PBD said that the 2018+ has a good factory CAI already & the only 2 aftermarket CAI’s that they’ve seen gains with are the JLT & the PMAS & it’s only 5-8 hp. Not worth $350.
mjpirylis
New Jersey
2019 GT Mt-82
Thanks
Wade
Thanks
Wade
According to AM the JLT with tune made 24+ hp whereas the Roush made 32+hp. Not much of a difference and could be related to the tune or conditions. Also the roush is like 100$ more so it’s really whether or not 100$ is worth maybe 8 hp to you.
birdword
Ca
2021 Mustang GT
I’d like to see what it gets with just a tune on the stock intake before changing it. Can’t imagine it’s enough of a difference to justify spending $400.
