JLT oil separator -569 miles
JolleyRoger
Californication
2015 Ruby Red GT PP
Not entirely correct. You could modify the bottom of your catch can with some kind of pressure check valve and when the car is off you could have it drain back into the oil cap or drain pan. I just don't know if there's a valve that is light enough where that little bit of oil will actually flow down through the valve.
Anyhow I'm sure it can be done, but it would require someone that is willing to put in the time, money and effort to get it done right.
How long does it take pressure inside the engine to die down to 0 after the engine shuts off?
As for the need of an oil separator, sure it does it's "job" but I don't know if it's really making any kind of difference in the performance of your engine. Is there any real data supporting the benefits of a catch can on an NA system. And I'm not just talking about seeing oil in your can. We already know it's gonna catch oil. But it doesn't mean it's really benefiting your engine any. Sure we all want a "clean" engine, but if the slime isn't hurting anything, you're fixing something that isn't broken. I know in extreme cases the oil can cause a reduction in octane and might cause you to pull timing. But has there been any of that in stock/bolt on mod NA form?
This sounds like a good idea, but "real data"...:lol::lol:
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
Showing you have oil in the bottom of a catch can isn't data supporting any benefit to performance, at least it's not unless you have data saying that amount of oil is causing a problem in the system....so yea "real data"
Trkn8r...from what i've seen through researching online. the drivers side doesn't really have this "issue" some oil gets by but it barely collects any
and another simpler way to get it to drain back in would be to apply the same check valve at the bottom of whatever tube you use. Then install a petcock at the can and just open it up every once and a while.
minicobra
California
www.thebandpetroleum.com
Braden
2015 Mustang Premium GT/PP
Since the early 60's when the PCV systems was first used by GM and then other vehicles, most if not all didn't come with an oil separator in the PCV chain. I've used these in the past, probably will use it again, but I too often wonder if it really is a necessary component, especially on a N/A motor.
Since they are not that expensive, I guess, better safe then sorry, or on the other hand, since I only kept my last 4 vehicles a maximum of 3 years/35K, maybe I'll just keep this off.
Eagle22
Northern California
Magnetic 15 GT PP
430 miles on my GT. Took the stock tube off with the assistance of my six year old daughter and we could see a thin layer or oil. Off it went 15 seconds later and two little pushes to snap it in and my little mechanic installed our JLT oil can.
Just the passenger side.
Tommy V
Brookly park Md
Tommy
If this was that big of an issue im sure ford would have addressed it, hence tougher emissions and having oil going back into the combustion chamber would definitely affect emissions. Buts its an easy bolt on and pretty cheap.I will just trust my pcv valve until I put a blower on mine.
stulaw11
I have a Bob's. For $110 (it and the JLT are around $100-110) I'd rather have the protection for a $6000 minimum engine to replace.
Tommy V
Brookly park Md
Tommy
I know im constantly hearing about the coyote,s blowing up because the pcv is inadequate.
Jeepwx03
PA
68 Mustang, 15 Mustang GT PP, 13 F150 FX4
Is this something that would be required if you have a supercharger?
Ruby305GT
Work hard, play harder.
Broward, Florida
2015 premium GT
It's not required, if you are ok with oil entering your intake plenum and don't care then that's fine. If you want to prevent it, you install an oil catch can or oil separator (same thing). If you are supercharged, you'll have oil coming back into your blower and intake as well. Why Ford hasn't done this from factory? No idea, maybe they deem it unnecessary.
Jeepwx03
PA
Judging by the amount of oil in the can by the OP, Ford probably hasn't because the average customer would never empty it
JASON@ANCHOR-ROOM
Portsmouth, VA
www.ANCHOR-ROOM.com
Jason
2015 Black GT PP
Tommy V
Brookly park Md
Tommy
When supercharging or turbo charging u dont use thh he pcv at that point, so a catch can would be a good idea.
Ruby305GT
Broward, Florida
2015 premium GT
Should be offered in the track package. I think the average customer of a PP are gear heads that know what they want out of a car and mechanically inclined.
