Jacking points and stand placement on s550
ChitownStang
Chicago, North Shore
2021 Mach 1
I just don't want to spent the money or have more weight on car. I know about the front K-brace area but the rear gets hairy
When I did Trans fluid I backed on ramps and then put the front on stands
I've seen people on youtube use the jack in the middle of the side rails with no rails, seems wrong!
[ame]
tj@steeda
Timothy
  • Like
Reactions: Ebm
ValidusTalon
North Carolina
2017 GT Premium PP + FRPP2
CJ Pony Parts has a pretty good tutorial located here: https://www.cjponyparts.com/resources/how-to-jack-up-your-2015-mustang
I tend to follow it pretty close... if just swapping a wheel I'll use a jack on the Jacking Rails, but if crawling under the car its either ramps or jack stands (or a combo). And as others have said, either set of rails are great, work perfect, and are from excellent companies - can't go wrong.
C.Stanley
C.Stanley
KY
2017 GT
So th BMR super low profile is a good choice?
AM is showing out of stock on Steeda and I need some ASAP
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
It is an outstanding choice. We typically have a hard time keeping up with the demand, BUT I do believe we just finished a large batch in Hammertone black color yesterday! You can order them from us direct with the code FS6KA on our web-site, or from a dealer - and they will ship asap :cheers:
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Just installed a set of the CJR002 over the weekend. They are awesome and it is SOO easy to get the car up now. The rail is just about 2 mm below the pinch weld flange. Excellent product.
C.Stanley
C.Stanley
KY
2017 GT
Thank you I just ordered them :cheers:
BMR Tech
Tampa, FL
Dion
I got the low profile BMR jacking rails in hammertone black. I was pleasantly surprised how heavy duty they look and feel. The best part is they're less than half the price of their regular jacking rails and I don't feel like you're sacrificing any build quality or sturdiness. Next BMR CB005 and CB006.
There is definitely a difference in cost, quality, design etc - HOWEVER, the CJR001 are a little bit overkill.
We were the first company to release S550 jacking rails, and in doing so - we always shoot for the best possible design from the get-go. Same with other items like our RLCA bearings, etc. Once others enter the market, we assess and see what additional changes we can make to compete at their price point. This can usually be seen when we have multiple components, often times labeled as "premium" (which is usually the no holds barred component) and the "standard" (which is usually comparable to other offerings on the market)
:thumbsup:
SidewaysMike
Somehwhere in the Med
2016 GT PP
I don't like using jack stands on the rail b/c when one side is up the stands seem unstable on the rails while raising up the other side.
I use the jack on the rail but still put the jack stand on the OEM pinch locations which rest deeply in the top of the jack stand.
The Steeda rails being shorter work perfect for this.
tj@steeda
Timothy
Currently offering a sale of said components above:
jimmerheck
Vancouver, Wa.
Jim
2016 Mustang GT Cal Special
I second that. I used them the other day to install my new mudflaps, and it seemed like they were bending in the middle when I had my jack in the middle of the door to lift each side. Next time I get a chance, I'm going to put a level or straight edge across each to see if they truly bent and stayed bent.
Update: I used them the other day to change my tranny fluid. I put a straight edge across them when I was done and they are definitely not bent, they are straight. So I apologize to Steeda and anyone else who may have read this for assuming they bent or would stay bent, they are straight as an arrow. Being they are this straight, I feel they do not bend when using them, or at least bend enough to be a problem and definitely do not stay that way. This is from placing the jack right in the middle of the rail when lifting the entire side of the car.
Barrel
Hoonigan
Cars and Trucks
I've used the Steeda rails at least 100 times right in the middle of the rail to get the whole side of the car up at once to put stands under the car for tire changes and other maintenance or part replacement and they've never deformed.
Everyone should feel comfortable with Steeda rails used like this as they're really designed with this in mind.
MaxQ
Australia
2016 Oxford White 5.0 GT
Best would be jacking rail and then anywhere along it. Someone else probably has the picture of the underside with points circled, but a lot of guys have and definitely recommend the rails from BMR (longer and not much heavier) and Steeda (lighter).
This is the picture Nagare was referring to,
Jacking rails are the way to go in the long term.
I am using the Steeda low profile ones.
