ISO. Pinion Seal replacement instructions.
ObnoxiousGt
SC
2015 S550 GT / 71 TORINO
Looking for instructions , PDF, step-by-step, etc.. about replacing my pinion seal myself. I've done numerous things on my car myself , but for some reason I'm not as confident with this.lol.
I've searched numerous threads on here but just cant find the answers I'm looking for.
WD Pro
United Kingdom
Lime GT
PM me your email - I have a pdf for rebuilding the diff that might help :like:
WD :like:
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
Can I get in on this?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Just remove the drive shaft, jack up car, check and write down breakaway torque, remove the pinion nut, pull off yoke, pry out old seal, seat new seal, install yoke install pinion nut, torque to same break away as before, install driveshaft
Some Random Guy
WA
Jeep Wrangler
I recommend counting threads too before removing. Extra insurance to avoid preload issues. My experience is not from the Ford though, so may be irrelevant.
ORRadtech
Atlanta, Georgia
Some of the things I've read suggest using a center punch to index the nut and count threads to return it to the exact point. Seems like you don't have to use a torque wrench with this method.
Never done it though, only read about it so take it for what it's worth...
Some Random Guy
WA
Jeep Wrangler
I’d use the thread count as more of an extra layer of confidence, the torque value seems more definitive as long as it doesn’t get hung up early on something.
Bahndvr
Roushcharged
Germany
What concerns me is the "staking of the pinion nut"
So the current pinion nut is staked, if so then I'll need a new nut?
Some Random Guy
WA
Jeep Wrangler
Yes.
All differentials I’ve done the pinion nut is 1-time use.
JohnVallo
1 5 4 8 3 7 2 6
Venice, FL
racersreunion.com
'16 GT350, Shadow Black, Whipple Supercharged
There are some tips in here (under pinion bearing/crush sleeve section) that may help you.
Inside the "Super 8.8" Rear End | 2015+ S550 Mustang Forum (GT, EcoBoost, GT350, GT500, Bullitt, Mach 1) - Mustang6G.com
As far as Instructions for just a pinion seal job, here are the best instructions I have found -from Ford-
View attachment FORDINSTSHTM-4851-M8A.PDF
Bahndvr
Roushcharged
Germany
Wow very insightful. I'm just trying to replace a leaking pinion seal. I don't mind doing it, I just want to know what all I need to replace and tools to accomplish. Thanks
