Hack
- Nov 26, 2014
- Minneapolis
- Mustang, Challenger
What I'm reading from your answer is that you don't know specifically how stiff the Magneride shock can get.If it's getting stiff enough to limit roll, it's not doing what it's supposed to, and would make the car feel horrible to drive. It's keeping the car feeling flat because of how slow it rolls, but roll it does. Keep in mind that the GT350 springs are around 40% stiffer wheel rate compared to your 15 GT (effective stiffness of the springs at the tire) by itself, not including the swaybars, which are also stiffer by a decent percentage. Those are actually reducing roll considerably. Combined with good damping, and it'll feel very flat and responsive.
The thing about Magneride is that it can be extremely stiff in compression and then be completely soft in compression depending on what the computer programming tells it to do. So when you say that if the shocks were programmed to prevent body roll then the car would feel horrible to drive - I'm not sure you were considering how the shocks can adjust when you said that. Why in your mind to you think Magneride can slow down body roll without a harsh ride being a problem, but if it were to limit body roll then suddenly a harsh ride will be a problem?
