Iron 8.8 power levels?
Nctong01
Kentucky
'17 Big Turbo Mustang Build, '17 Turbo Silverado, '16 AMG GTS, '99 Turbo Integra
I have a single turbo coyote project in the works that will be aimed at 1500whp ran through a TH400. I've searched and searched but no luck in finding specs on differentials for guys running these power levels. The ones I do see are running a 9 inch, but I'm wondering if anyone has the experience running higher power on an iron 8.8.
andrewtac
TX
mark
F250. 2020 GT 400A
Interested as well, still have aluminum but going up in power soon.
drive_55_not
S,East
2014 Coyote, S197 3v, 2018 Gen3 [RIP], 2020 Challenger 'Cat
Avispa
Oldsmar, FL
Richard
2016 Mustang GT/CS convertible
Even Chevy people use a Ford 9 inch for peace of mind. Good friend put a Strange housing one in his '57 Bel Air. Kinda like Ford guys using a TH400. Some parts are just the best at what they do.
GenerousLemon
2020 Mustang GT and 1999 Ranger V8 swapped
I’ll tell you the issues I’ve seen. First hand experience btw, bent diff bolts after about 20 passes, broken spider gears, and broken diff bolts. This particular car cut 1.1x 60s at 4000 lbs race weight. If you have the means, get the 9”. It will save you headaches in the long run.
Avispa
Oldsmar, FL
Richard
Wow. Bent differential bolts. That would seriously ruin my day. Dont think I've ever seen that.
9 inch also has a feature that no other rear end has, a bearing for the nose of the pinion gear. Reduces weirdness from torque load, which is where a lot of failures start.
andrewtac
TX
mark
F250. 2020 GT 400A
1.1 60s at 4k, how much power was it making, that is fast.
GenerousLemon
The car made 1600 on 35 pounds of boost. When he cuts that 60 he’s leaving at 4K rpm, and the boost ramp is set to .5 seconds all in at 25 psi. If I had to guess, about 1400 wheel.
Nctong01
Nctong01
Kentucky
Appreciate the input. The goal is about 1400 wheel and leaving off a transbrake so I guess I'll do it right the first time.
Jackson1320
California
Jaxson
2015 mustang gt
The aluminum diff gave out around 700wheel for me but the iron is holding at 900wheel but I can not see it holding 1400 for long
andrewtac
TX
mark
F250. 2020 GT 400A
What was the rest of the setup? I am close to 900 wheel and have made probably a dozen or so passes on the aluminum.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
I guess my aluminum diff is on borrowed time. I am adding the diff support in spring.
Jackson1320
California
Jaxson
2015 mustang gt
I have seen aluminum diff’s go higher than mine did. Mine started howling very loud. I had the diff on solid mounts and support in place. Maybe i was just unlucky but my iron diff was only $300 shipped so not a big deal
andrewtac
TX
mark
F250. 2020 GT 400A
In the plans for me for sure, prior to the motor for sure.
GenerousLemon
We have a 20 pass rule. Chunk comes out new diff, new diff bolts and fluid obviously.
