iPhone charging
rwp50
New Lenox,il
Bob
2017 Black California Special
All of a sudden my iPhone 11 won’t charge through either the console or under radio USB ports. Never had a problem before.
Jeffsmith
New Jersey
Jeff
Mustang gt 2008
I noticed if I unplug my iPhone and replug it that sometimes happens. Does it happen when you connect for first time after car starts ?
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Have you tried a different (and known working) cable? Also, some lightning cables get damaged on one side, so while the design is supposed to work in either orientation, it'll become "one side only" for charing.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
It's almost always the cable.
MikeHTally
North Florida
2015 EcoBoost Mustang, 2020 Explorer Limited
blind*guardian
Reseda, CA
2019 Mustang GT
Concur with the cable the likely culprit, but if not, then certainly check that you're getting power from the USB port by plugging in something else. If no power, check the fuse.
rwp50
rwp50
New Lenox,il
Bob
yes. This just started. Nothing has changed in the car. A totally stock black ‘17 California Special. Have never even red lined it.
opengl
PA
2018 GT PP1 400A 6MT
That's good because everyone knows the USB ports stop working if you redline the engine
rwp50
rwp50
New Lenox,il
Bob
rwp50
rwp50
New Lenox,il
Bob
Next post:
"At the dealer, got the oil changed and tires rotated ... did not fix the iPhone charging problem ..."
changed cords, no luck. Purchased a cigarette lighter adapter and it works fine. Go figure.
rwp50
rwp50
New Lenox,il
Bob
will do tomorrow!
Thanks
which fuse? Nothing specifically identified powering the USB ports.
Bikeman315
Myrtle Beach, SC
Ira
