Intermittent starting issue
samanthalang315
Ocala, FL
Samantha
2017 Shelby GT350
Hey guys, new member here.
I have a 2017 with about 20,500 miles on it. I seem to have an intermittent starting problem which seems to happen at random times (happens during a cold start, and has also happened after driving the car for around 30 minutes).
We have tested the battery voltage, alternator, fuel pump pressure, fuses in the engine bay, starter, and starter wires all of which checked out fine. Ford has also looked at it for a week and couldn’t find anything. What I have noticed though is when it does mess up the clock resets to military time.
Has anyone had similar issues and was able to figure out what the issue was?
pilotgore
US
A bunch
Welcome!
Between my experience and that of other members, I’m guessing it’s either a weak battery (even if it tests ok), or a starter (or solenoid) on its way out. Particularly the bit about the clock resetting leads me to lean towards a battery.
samanthalang315
samanthalang315
Ocala, FL
Samantha
2017 Shelby GT350
Welcome!
We will test battery tomorrow, thank you!
loco_GT350
Tempe, AZ
2017 Race Red GT350
I had a similar issue with my 2017 about 7 months ago. I checked the battery and if I remember correctly it seemed to be okay from a voltage point of view. I decided to replace the battery due to it was 4 years old. After I changed to the new battery the issue went away.
Not sure if this the same thing as what you are seeing but a new battery fixed my issue.
Tomster
Beware of idiots
Tom
Op, if you replace the battery, there is a battery reset that should be used. Search it.
RPDBlueMoon
California
GT350 Heritage Edition, Civic Type R
I can attest to this. Just spent the last 6 months dealing my whole electrical system being fucked because I didn't reset my battery when installing the new one. I honestly didn't believe these cars were that complicated but I was wrong.
