xr4x4ti
Can someone confirm that the Magnum XL angles the transmission about 5 deg counter clockwise when looking from the back of the car? Is the shifter base angled toward the driver?
Thanks,
Tim
Thanks,
Tim
Thanks,
Tim
Can you help me out? I had the same trans installed by a mechanic in my 2015. I got the same all in one harness. My reverse camera won't come on. Can you tell me or show me if you have pics, which wires are responsible for making the reverse camera work? I have a feeling this wire wasn't connected. I've been searching all over the web and can't find an answer. Thank you!Took on a new project and thought Iād share it. Never thought Iād go this route but but just saying that doesnāt really surprise me.
Backstory: The car is a 16 PP so it has the 3:73 rear gears and is pretty heavily modified. Like most of us, I ran the MT82 with an MGW and had no real issue especially after adding that shifter. I didnāt break anything in my stock transmission and it worked the same from the day I bought till the day I took it out. For 28k miles I ran the stock clutch with it and I was fairly quick to add a Whipple and shortly after that E85. I was amazed at how well the stock clutch handled it. I do occasional road course days, and as some forum members can attest to from riding shotgun, I push the car hard and play with the line of limit. The 3:73 differential made 1st and 2nd gear pretty useless at my power level and considered changing diffs but didnāt want to ditch my Torsen. I donāt do 1/4 mile runs and for the most part I daily drive the car which includes commuting to work in traffic. The car is literally 95% street with casual manners and 5% track/canyon carving/hurt the feelings of another car brand/owner that unwisely has challenged.
I bring up this info because it has a factor in making choices in parts and gear selection. Also, my baseline is can my wife take the car out and drive it ānormallyā without it being annoying/difficult to operate and that applies to me as well.
This is what I ended up buying and most of this comes in a kit which is the route I went:
Tremec Magnum XL transmission (duh)
First gear choice of 2.66 and opted for the 5th and 6th OD gears of the 2.97 trans which gives me in order of 1st to 6th, 2.66/1.78/1.30/1.00/.80/.63
Quick Time steel sfi bell housing
QA1 carbon fiber driveshaft with sfi (upgrade)
Bowler all-in-one harness for electronic connections
Rest of the kit included fluids, transmission mount, cross brace and mounting hardware
Also added the MGW shifter since I really appreciated what it did for the MT82
The clutch was a difficult and time consuming process and there is a endless amount of choices out there. Everyone has their preferred brand or special purpose for what their plans are for their car but this is also the reason I gave the back story above because it applies here. I would love to try all brands and models that I narrowed it down to (probably 5) but Iām not sponsored, a company that works in the industry nor someone with unlimited funds. My personal requirements were something near stock weight for stored energy, sprung hub and organic. I was open to single and dual disc setups knowing the inherent differences. Ultimately I went with the Ram Pro Series twin disc organic with steel flywheel.
Like I said, plenty of great choices to go with and I even tried for a short period, which was completely non cost effective for me, a Mantic 9000 organic series clutch which I will say was awesome with my MT82 the short time I had it. I could have easily just switched to 26 spline clutch discs but the light weight would have been an issue I feared so I did what I did.
Hereās some pics cuz thatās all most care about....
At current writing, Iām around 300 miles on the break in. At first, and at around only 25 miles I thought I made a mistake with clutch choice. First gear start off from a stop had significant chatter but that has quickly become better and better and Iām sure will continue to get better as smooth slipping start off has become an easy thing to do now. Recently took the wife out to mess around with first gear in a parking lot and she did great but could notice the current difference. If youāre already moving, this clutch is just perfect. Clutch pedal effort is less than stock, initial grab and capture is well within the throw of the clutch pedal; not quick off the floor grab or late grab near the top. Iām 90% happier with the clutch than my first quick to judge impression.
I cannot say enough about the transmission. I absolutely LOVE the gears I chose granted Iām in the break in phase and not shifting over 4000 rpm for the most part but again, this is how the car will be driven most of the time. First and second gear are so much more useful and enjoyable to use. Fourth gear (1.30) in the MT82 was one of my most favorite gears to play in and also was a factor in choosing the magnum gear selection I did because third gear in this set is also 1.30 which made it perfect. 4th is now the 1:1 gear which I like and the two OD gears are gapped perfectly unlike our 5th to 6th is in the 15-17 MT82. I will say it is weird downshifting to 1st gear around corners in residential/commercial zones but itās easy, called for and works like any other gear youād be used to using normally. Hell, Iām still learning what gear to be in based on muscle memory of where the shifter used to be. I really couldnāt be happier with how this all works together and with the stock 3:73.
The driveshaft is awesome and the second QA1 I have owned and also part of the not a wise investment in regards to how long I had it in the car before switching to the Tremec. Iām sure itās not the last time Iāll do that.
One other thing when I first got it on the road and getting a feel for it. There was a small vibration/drone in the car that came in around 3200 rpm and went out around 3800 rpm. Believe me I thought of every possible scenario and incorporated lots of others thoughts to the mix so before you start throwing out ideas, it was figured out. There is a reverse lockout solenoid that is on the drivers side tail section of the transmission and it was touching the body lightly. The idea of what to do was easy but the process of doing it wasnāt quite so easy especially without removing things. It took a small hydraulic ram to push, which happens to be a much stronger and stiffer section than I expected, the body panel away which now looks like this, totally fixed the issue and might as well be a mile away compared to what was before.
This is the electronic harness that was included with the kit and sold from Bowler. It incorporates all electrical connections and really made everything work easily and its adjustable for things such as tire size, OOS pulse calibration and reverse lockout parameters to make to your liking (speed at which lockout engages or deactivates). Reverse switch is a no brainer. Literally soldering 5 total wires to the original trans harness to make everything connect; the two reverse wires and reverse camera and light work like stock. Positive, ground and oss wire.....done. You download an app to your iPhone or android and and it Bluetooth connects when ever you want for changing parameters. Without going into too much detail, just go with itās easy and works great. All connectors to the sensors on the trans are OE style and weather sealed.
In regards to the actual install, itās no more difficult than changing a clutch if youāre comfortable with it. I really liked the separate bell housing.
Thatās all I got for now. Still have miles to go before it all gets more aggressive testing but I have no doubts.
Hey Tim just saw this and it was definitely a head scratcher when we installed my Magnum but yes it is designed to have the shifter rotated towards the driver. The Tremec engineer said it mimics the stock rotation to place the shifter closer to the driver.Can someone confirm that the Magnum XL angles the transmission about 5 deg counter clockwise when looking from the back of the car? Is the shifter base angled toward the driver?
Thanks,
Tim
All agreed, except that usually doesn't cause failure, it causes shifting problems, especially at high RPM (when it's out of center or not parallel).That's interesting, I know Tick has a really good reputation. How well indexed was your bellhousing to start with? Tremec specifies a really tight tolerance for parallelism and concentricity for high RPM applications. I'm working from memory, but I believe it's less than 0.0005" (0.001" TIR) in parallelism and less than 0.0025" (0.005" TIR) in concentricity. They really don't tolerate being out of alignment, apparently. I had to add several shims to dial in the parallel dead nuts and it took a set of .007" offset dowels to get the concentricity to about 0.004" TIR. I'm not saying that it caused your failure, but might have contributed, one more variable to eliminate.
How loud is that pump? Any idea of the gears are helical cut or straight?So I broke my magnum XL a few weeks ago, input shaft gear broke, was only putting out about 650 whp at the time, but was 30 min into a hard road course session.
Apparently under hard acceleration like road course and half mile / mile events the oil sloshes to rear of transmission and the front gears get starved of lubrication and then fail.
Tick Performance have an upgraded front plate with an oil spray bar and pump to pump oil to these front gears. Also comes with cryogenic treated gears and micro polish. Sharing this for the guys who need to take there magnums to the next level.
Havenāt checked it as carefully as that, just assembled it with the bell housing as it came. Hopefully not causing an issue for me.That's interesting, I know Tick has a really good reputation. How well indexed was your bellhousing to start with? Tremec specifies a really tight tolerance for parallelism and concentricity for high RPM applications. I'm working from memory, but I believe it's less than 0.0005" (0.001" TIR) in parallelism and less than 0.0025" (0.005" TIR) in concentricity. They really don't tolerate being out of alignment, apparently. I had to add several shims to dial in the parallel dead nuts and it took a set of .007" offset dowels to get the concentricity to about 0.004" TIR. I'm not saying that it caused your failure, but might have contributed, one more variable to eliminate.
Havenāt run the pump yet, still trying to figure out where I want to mount it. Gear look straight. For duty cycle they want you to only run the pump under boost, so Iām using the same relay circuit that turns on my 2nd fuel pump when boost comes in.How loud is that pump? Any idea of the gears are helical cut or straight?
How about duty cycle? I didn't see any of this on the website so figured I'd ask...
Was using Amsoil ATF when it broke, and going to try Redline high temp ATF next. I donāt think the oil was an issue, I sent it in to blackstone and they said it was perfect, no red flags.Just out of curiosity, what fluid/lube were you running before, and what will you be using going forward? Amsoil ATF?
Revisiting this question about shimming the slave. I used a endoscope/borescope and took this video of my slave. Any idea how this looks compared to yours with the shim? I'm curious if I have enough travel.@Ruiner46 Great news your car is back on the road! It sounds like your setup is just fine with the clutch engagement.
I was able to find one guy on SVTPerformance forum that put a Magnum in his GT500 car with a McLeod RST and needed a shim of just over half an inch. But it does seem most just install and go without any issues.
My Magnum is the wide ratio 2.97 first gear setup. Maybe there is a different with the close vs wide ratio? Iād be curious to know the measurement of the slave mounting point to the face of the bell housing on a 2.66 trans. I did measure from the tip of the input shaft to the face of the bell housing on my Magnum and broken MT82. That measurement was the same, so Iām confident the bell housing is correct.
My shim arrived from McLeod yesterday along with my clutch that was cleaned up and balanced. My plan is to install the flywheel, clutch and bell housing on the car and take my āAā measurement again. Then take the āBā measurement on the trans with the shim installed. Just wanting to validate my numbers one more time and report back to McLeod to get the green light before I wrestle the trans back into the car. Itās freezing cold here in Chicagoland, so I need some decent weather too!
