Im having issues I don’t know what to do any help is appreciated.
bobhadababy91
Charlotte
Alan
2015 mustang gt
So one day I lost power steering traction control advance trac and the turn signals quit working. Now the air cuts high-low randomly. I’ve asked around many ppl have told me sounds like a ground problem ok I checked the grounds. On the shock towers looks good no issues still having the problem has anyone had this issue? What can I do to fix it without taking it and spending 10,000 bucks.
NTXChris
North Texas
2019 PP1 GT
Have you had the battery and charging system tested? These cars are very sensitive to battery condition/voltage, and a failing battery or even corroded terminals can have a big impact on the performance of the electrical system.
JCF204
Colorado
08 F-350
Electrical gremlins can always be a chore to trace. You could also have a positive wire that is heating up and shorting out. I would make sure all wires look clean and none are able to rub close to metal especially as it gets hot.
It wouldn't hurt to have a local auto parts store do a free scan on it, you never know some error could pop up.
Good luck
bobhadababy91
Charlotte
Alan
2015 mustang gt
I have not had it tested I’ll try and see if this works I appreciate the feed back. I did check the terminals and cleaned just to be safe.
bobhadababy91
Charlotte
Alan
2015 mustang gt
Good luck
Thank you I’ll definitely double check and make sure. So the auto parts store ran a code didn’t read any my buddy has a high dollar scanner and his picked up 28 codes ecm/pcm being one of them
JCF204
Colorado
08 F-350
I would double check that battery, my taillights started to malfunction and so I started shopping for new ones. Then I read on here somewhere about a weak battery can cause this. Put in a new one and no more problems since.
And that is much cheaper than a PCN replacement. Probably worth it.
y2ksilverbullit
Nashville, TN
2000 GT 5M, 2001 DHG Bullitt, 2015 GT 50 YR LE A6
I second @JCF204. Same taillight issue when battery wasn't staying charged. GL!
bobhadababy91
Charlotte
Alan
2015 mustang gt
Checked the battery it’s at 12.6 volts and holding. Here are the codes it’s pulling mostly modular codes. Someone said maybe a body control module.
I would look around the engine bay and under the car at all of the visible electrical harnesses and see if there are any a rodent got to and chewed through.
Use a bright LED light to look at everything. While checking for such rodent damages, also make sure that every harness connector is securely plugged in - give them a good push together even if they look like they are plugged in.
Oakley
Lee
2022 Mustang
voltage while running should be around 14.6V. if it isn't that its likely somthing to do with your alternator. cars do wacky stuff when they dont have the right voltage especially when they have as much modern conveniences as these cars have.
bobhadababy91
Charlotte
Alan
2015 mustang gt
ok I’ll check it out I appreciate the feedback.
Mizzle51
Green Machine
Vancouver, WA
2021 GT Prem PP1 Black
What's the age on that battery?
My 15 about 3 years in had random electric bits glitch (infotainment, taillights, pony lights all went out randomly) for about a week and then the battery was completely dead and it was a no start. Now I just rip and replace the battery around 3 years in as a matter of consumables.
twbthird
St Louis MO
Tom
17 GT Premium PP convertible, Ruby Red
I have a low mileage '17 that is still on the factory battery. I think using a battery maintainer (not just a trickle charger) has really helped battery life and have had no electrical issues.
y2ksilverbullit
Nashville, TN
My factory battery lasted almost 7 years. Replaced it with an Odyssey AGM and no problems since. AGMs are a bit pricey, but worth it in the long run....
2016 Mustang GT PP
99% of the time, if your battery is approaching or older than 3 years old... its the battery.
They don't always test bad when they're failing. My last 'normal' battery tested just fine and then was dead as a doornail the very next day.
