Madtel4
So the way you say to do it you will have 2 cycles not just one. Your valve spring all 32 of them on a GT are cycling all the time that's what springs do. The pressure plate will probably last 200K without shifting to neutral at every red light. (PS you should raise your ass of the seat at stop lights as to not overstress the seat springs)Well when pressure plates are designed and engineered, the material chosen are based off of desired "cycles" over it's lifetime within a certain temp range. Generally a "cycle" would be and actual shift event, not depressing the pressure plate over extended periods of time. Sure some of that is factored, but as far as I know, not to the extent as described here.
With that said though, I don't mean in anyway that your pressure plate will be destroyed overnight, just simply wanted to state that "clutching in" all the time when at idle for a light our whatever, can cause abnormal fatigue, which in turn can cause early failure.
Lee
