engineermike
Lund said if you lower the compression 2 numbers and make no other changes then you'll lose 50 hp. That's a pretty accurate statement. But Lund didn't mention that lowering compression 2 numbers also buys you a ton of knock margin, nor did he mention the possibilities that opens up.Your tuner, Lund, is telling you unless you are ok with less power don't do it.
If he were to lower compression one number, then raise the boost to make the power back up, when the knock margin and safety is actually improved on any given octane, assuming he doesn't add more than about 3 psi.You can try a pulley that is rated for more than 10PSI, but keeping that safe is on you and 93 might not always be up to doing that.
If the tuner uses the same borderline and MBT timing curves (and torque-to-load and load-to-torque tables, for that matter), then you have the wrong tuner. An actual calibrator would calibrate those tables for the compression ratio, which is the root of the problem with letting tuners design your combo. Tuning an engine with a different compression ratio means they can't sell you the rinse-and-repeat tune they've sold a thousand of before. It actually takes a lot of time, especially if done remotely, and most customers aren't willing to pay for that. But I think you already knew that.When you lower your compression, and the tuner still has you at a now soft timing curve for a higher compression engine.
It's true that lower compression increases EGT...well...technically the lower expansion ratio is what raises EGT. But another thing that raises EGT is retarded spark timing. Lots of supercharged gen3's are running 12-14 deg of spark timing, which causes high EGT as well. So what has a higher EGT...a 9.5/1 GT500 running 25 deg timing or a 12/1 Gen3 running 13 deg timing?Your exhaust will be hotter, therfore catalytic converters will run hotter and be at higher risk of melting. Just something to think about. Listen to your tuner.
