I need help lol
Geis153
Pennsylvania
Aaron
2018 mustang gt
So I installed oil pump gears 2 weeks ago. Car ran fine. Drove it home from the shop I work in let it run for a while no issues. Drove it a couple times and no issues. Went to the end of my road, let the clutch out and it died. Won’t start. Went back over all the wiring nothing unplugged. All I have is a p162F code. Fuel pump module maybe? Thank you in advance
Ock
Tn
Tom
2018 GT Premium and a 1966 c10
i googled it and see "P162f is a starter motor disable engine crank too long code" Did you try turning it off/on again? But idk.. see this? https://www.engine-codes.com/p162f_ford.html
Did you do the crank relearn procedure too after the OPG work?
I did not I didn’t know I had to? So how do I do that I have an nguage tuner?
Check the pdf in this linked thread; any time there is major engine work or trans work performed on the S550 5.0, the Dealer Service Tech (or DIYer) is supposed to do a crank relearn procedure.
https://www.mustang6g.com/forums/th...s-weird-hesitation.125119/page-2#post-2679084
Also check this link if you have a n-gauge for crank relearn:
https://www.mustang6g.com/forums/threads/new-clutch-dtc-and-shudders.148583/#post-3035678
  • Like
Reactions: Ock
Geis153
Pennsylvania
Aaron
2018 mustang gt
Geis153
Pennsylvania
Aaron
2018 mustang gt
Unplug the battery and let it sit for a couple beers worth of time.
Haha yea I tried that too I’m kinda lost. I didn’t do the crankshaft relearn after the opgs but it was running fine after that. Don’t think that should cause a no start
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
A while back, my 2016 EcoBoost refused to start after I'd parked it. Turned out to be a bad low pressure fuel pump. It failed with no warning....... It's easy to check if you have a bi-directional scan tool. You need fuel, air, and spark to make the engine run, I'd start with the basics. Lack of crank relearn should not cause a cranks but won't start issue........
Geis153
Pennsylvania
Aaron
2018 mustang gt
Does anyone have access to wiring diagrams newer than 2014 vehicle power number 4 fuse keeps blowing as soon as I turn key on
