HRN-AR-FO3 harness Modification?
Yilly1108
California
Phillip
2018 Ford Mustang Ecoboost Premium w Performance P
Good day to all. I know that this topic is old news. I'm going from a Rockford Fosgate DSR1 to a MARTS dsp and would like to use the HRN-AR-FO3 harness as it is plug and play. Does anyone have input that does not involve going behind the head unit etc?
S550HPP
PDC
2022 HPP Vert
Simply attach new amp harness to HRN ends and plug HRN plugs to kick panel head unit plugs. I used the HRN on two different amps already and will use it on other ones as well.
Yilly1108
California
Phillip
I don't know why I'm making this so difficult. I guess I need pictures in crayon😂😭
Yilly1108
California
Phillip
It's actually a MARTS BXT8 Dsp and it doesn't come with any harnesses. It takes RCA inputs. That's my dilema
S550HPP
PDC
2022 HPP Vert
Just connect the RCA plugs to corresponding HRN wire ends. There's a diag here somewhere on the head unit wires extended via HRN
Yilly1108
California
Phillip
Gotcha. Thanks
Yilly1108
California
Phillip
Does it matter which corresponding HRN wires I connect to?
MiamiGT350
S. Florida
I can't speak to your specific model, but perhaps this will be of help.
I used a HRN-AR-FO3 harness to pick up the factory signals and feed them to a JL Audio Fix 86.
There are black and tan plugs going from the head unit to the oem amplifier in the drivers side foot well. I connected these two plugs to the F03 harness, then cut the harness wires to feed them into the Fix 86.
Here are the wiring diagrams/posts I referenced: https://www.mustang6g.com/forums/th...o-systems-no-loc-required.159271/post-3244386
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
What didn't you like about the DSR1?
Yilly1108
California
Phillip
Thanks for the help.
My particular unit loses connection alot. 2ND one I've had. Had to send the first one back. Now the problem persists
TonyT930
Philadelphia, Pa.
Tony
Did you download the very latest software update off of Rockford Fosgate? The Bluetooth problem is a known problem, but the new software corrected the issue. I had the same problem. Now it's fixed
TonyT930
Philadelphia, Pa.
Tony
Also remember, if you go out of the app, the Bluetooth will disconnect until you open the app again. This is a known annoyance
Yilly1108
California
Phillip
About 3 weeks ago? The unit has started doing it again.:(
TonyT930
Philadelphia, Pa.
Tony
Damn Brother, ok. Sorry to hear that. Have you reached out to Rockford?
Yilly1108
California
Phillip
Nope. Kinda exhausted with it. Warranty is over plus I just purchased the MARTS dsp. Hearing good things about it. Just trying to make sure I use my leftover idatalink harness correctly because our system is so "complex"😭
