MakStang
- Dec 11, 2016
- Greece
- Website
- www.cellentis.uk
- Makis
- A 2017 miraculous little beast
Update on this topic.
A couple of weeks ago, I read somewhere that there is not just one, but two mics that are part of the active noise cancellation. Most of us have only disconnected the one located under the headliner. There is another one located inside the map light box, but this mic seems to be important for other functions as well, so I guess it should not be disconnected.
I decided to use FORSCAN to deactivate the active noise cancellation (ACM module 727-01-01). By doing this, the ANC is completely disabled. The sound of the MBRP Race Exhausts is much, MUCH better now. Drone never bothered me, as I wanted a loud exhaust system, but without the ANC it's now more quiet inside the cabin and the sound of the exhausts is a "raw", pure growl.
Also - and this is not simply my idea - the sound system sounds definitely better.
I suggest that you give it a try, it's worth it. To avoid buying an expensive Bluetooth or WiFi adapter for use with FORSCAN, you can buy a USB adapter such as the one I bought on Ebay. It works perfectly with FORSCAN, as it can read and write HS and MS-CAN modules:
ELM327 USB modified for Ford ELMconfig FTDI chip HSCAN / MSCAN Forscan OBD2
http://www.ebay.com/itm/271935399987
