How much Power With Hellion 55mm Turbos
Chevpwr
Oklahoma
Lee
2015 GT A6 Vert
Has anyone made over 900whp with the S550 Hellion twin turbo system using their 55mm turbos besides Sheldon Lewis and Hellion?
beefcake
Bethel
2018 Ford Mustang
its all how far you want to push it
the 55s have made over 1000 wheel,
the potential is there if you want it.
typically 900 rhwp is what we tell customers, if your dead set on 1000 wheel then go with the 62s
but the 55s are pretty mean
Chevpwr
Chevpwr
Oklahoma
Lee
2015 GT A6 Vert
I already have the 55's, check my sig.
Chevpwr
Chevpwr
Oklahoma
Lee
2015 GT A6 Vert
I forgot that I had this
PowerAdderGT
Mustang
What year car was that test done on and what was the boost?
Chevpwr
Chevpwr
Oklahoma
Lee
2015 GT A6 Vert
If you are talking about the above, I thought it was for a S550. The boost is listed on the sheet. As far as I know the 55's are only available on the 2015-16 kits.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
This may or may not be the case with the dyno sheet you listed. Almost every sheet I have seen from Hellion is corrected with a 18-20% correction factor when on the dyno.
I think anything beyond 800 I would go to the 62mm.
HELLION TURBO
United States
2015 Mustang GT
Hello.
We have made 1135 rwhp with the base 55mm kit. The mods included an MMR 1500 short block and valve spring upgrade for that pull.
Hope this helps!
Chevpwr
Chevpwr
Oklahoma
Lee
2015 GT A6 Vert
Hello.
Hope this helps!
Is this Jeff, if so I'm still waiting on a call back.
Thanks,
Lee - Oklahoma
HELLION TURBO
United States
2015 Mustang GT
Thanks,
Lee - Oklahoma
This is not Jeff, however he should be in later this morning and can help you.
