Gen 3 coyote with Hellion TT 62s on 18lbs, how much WHP
jbanh100
Houston
Jackie
2021 Tesla Model 3 Performance
1048 at 16-17 lbs if i remember correctly bottom mount kit
e85 ofc
Beano
Melbourne Australia
Phillip
FGX XR8 and 2016 Mustang GT, Both supercharged
General rule of thumb for Turbos is that you will double the hp at 1 atmosphere boost, thus 2x at 14.7psi.
‘’Take your current hp, x2 and add another ~18% on top of that. Assuming a rwhp figure of 460hp on the stock Gen3 coyote, just for sake of the example, I will estimate close to 1,088hp on the flywheel, or ~1,000rwhp, of course depending your transmission-type, assuming a manual box here.
This is just theoretical though, would be interesting to see what you make in practice, as air-temperature and thus density will also play a significant role, you might hit 1,100+ rwhp in colder air....
Cheers,
‘Beano
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
1037 hp
gimmie11s
SoCal
Murica!
18 lbs on 62s ought to make over 1100...
I made 913 whp on ~11 psi with twin knock-off 67s.
15GTPP
El Paso
2019 GT
Over 1100hp easily. I put down 1039/850 on 15lbs. Hellion Sleeper kit with gen 2 6266 turbos. Pump e85.
15GTPP
El Paso
2019 GT
Whats it run?
The local track closed down a couple years ago. The nearest one is about 3-4 hours away. I’d love to get a couple passes in one day.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Ah dang. Seems to be happening all over.
erikkire18
erikkire18
santa barabra,ca
5.0 Hellion TT
I plan on going to the dyno next friday and doing quick logs with lund. im at 14lbs now so adding the extra 4 won't take long. Just making sure everything on my end is good so I don't false knock
15GTPP
El Paso
2019 GT
The adjustability on these kits is awesome. What boost controller are you using?
erikkire18
erikkire18
santa barabra,ca
5.0 Hellion TT
yah being able to pick boost is helpful and fun. i got the gfroce II but i am looking to get the eboost controller so i can do boost by gear. I run 10lbs right now but have it set it 10 12 14 lbs.
15GTPP
El Paso
2019 GT
Nice! I actually have my settings the exact same. I have the eboost2 and have heard the boost by gear works well with the cortex. I tried to figure it out with the eboost but haven’t had any luck.
erikkire18
erikkire18
santa barabra,ca
5.0 Hellion TT
yah boost by gear would be good, 3rd gear would get all the boost hahaa
