erikkire18
- Apr 12, 2018
- santa barabra,ca
- 5.0 Hellion TT
I don't know how your eboost controller works, but on my Boostleash, you don't set it to say 12 psi and expect 12 lbs of boost. If I set it to 12 psi, its adding 12 psi to the top of the wastegates holding them closed longer. So for instance, on wastegate pressure without the boost controller, I see 8lbs of boost. If I add 5 psi using the boost controller, I end up seeing 12 lbs of boost. If I add 10 psi using the boost controller I see 16 lbs of boost. Its not a 1 for 1 correlation. You have to figure out how much to add to the top of the wastegate to get your desired boost reading.
oh I see what you mean, yah It was set up previously by the shop where I dynoed it at. I gotta see how to reset the duty cycle and adjust the controller. I got a GFB II controller
