dsm_mikey
Are you concerned about vibrations from the lack of the damped oem flywheel? I thought the flywheel is part of the solution the Ford engineers came up with to quell the flat planes vibrations. I am sure you thought of this. Curious as to if it will have an effect on durability...
How much total weight are you shaving just with this mod?
Thanks!
Thanks!
Ho boy! She's here and she's MAGNIFICIENT!
This is the full race setup from Spec. Billet AL flywheel with maximum weight reduction and their 184mm twin disc road race assembly.
As seen above, the pack is only a bit over 8in at widest.
Compared to the OEMs 10.75-ish
So how are we looking for weight? OEM clutch pack is about 19.6lbs.
The entire Spec clutch kit is 20.6lbs, effectively eliminating the entire OEM flywheel worth of rotational mass.
Rowdy!
