High idle, up to 2K
Sloth50
So Cal
Marq
2015 Mustang GT
Having an issue while stopped at a light or just stopped in general, my rpms rise up to 2k rpm then throws P0507 code. I also have a P0300 and P0316 both random misfire codes. Plugs look fine and pcv valve is new. Any ideas on where I should look into to find the fix. TIA
2015 GT, 6spd, 18 ported manifold, 47 lbs injectors and running E85
Yes I have checked other post about similar issues. Also, when I put it in gear and ease off the clutch while holding the brake, rpms come back down to normal (roughly 750rpm)
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
Could it be a mass air sensor in the intake?
TonyT930
Philadelphia, Pa.
Tony
I’ve removed that and sprayed it.
By chance, do you have an air filter oil element and just cleaned and recharged it recently?
Sloth50
So Cal
Marq
2015 Mustang GT
New JLT intake and filter. I will give it a clean but I haven’t put many miles on it by any means!
TonyT930
Philadelphia, Pa.
Tony
Just please be sure you let the filter dry and don't over oil it. The oil can get on the air sensor resulting in a problem. That's what I was told anyway. Question, is there a chance that the air sensor is installed incorrectly or in reverse? There should be an arrow on the sensor for the direction of air flow I think.
Torched10
Atlanta
Bob
If it were me I'd take out the jlt and see if high rpm goes away just as a test
Sloth50
So Cal
Marq
2015 Mustang GT
Wouldn’t I have to change the tune if I went with a stock air box
SheepDog
Colorado
Dax
What do your fuel trims look like? Also, does your ported manifold have lockouts for the IMRC flaps?
