Help with a weird engine noise
fpa1974
GA
'19 GT350R
I will start by saying this is not on a 350 but having so many knowledgeable and helpful people here convinced me :)
I recently got a 2012 Boss 302. Car is stock and runs great overall. Recently though it developed this very interesting noise most obvious front passenger side valve cover. It sounds like a crackling. I tried swapping out coils, left/right but that made no difference. I am wondering what the heck it can be. It starts only after about 30-60 seconds after the engine is started. Any ideas are welcome.
Thanks a lot!
The link to the video (for sound primarily): https://www.icloud.com/sharedalbum/#B19G4TcsmtcyNr
sox3
Newark, Delaware
George
2019 GT 350 Performance Blue
Could it be check valve inside the PCV? Disconnect the PCV line to see if it stops?
Scoobs
Ontario
2017 MG GT350 sold, 2019 MG GT350R KR569
AC compressor need to be recharged/oiled? That was a problem on Fox bodies that fixed a sound like that?
fpa1974
GA
'19 GT350R
Good point! I will try disconnecting the AC belt and see. AC compressor was charged (not oiled BTW). Thanks!
fpa1974
GA
'19 GT350R
I checked the PCV check valve and the black stem in the middle of it is extremely loose and when moved by hand with the engine off makes that click clickity sound I hear. Is it normal for that black stem to be moving loose with the engine off?
fpa1974
GA
'19 GT350R
Just an update. It was the darn PCV valve (which BTW is the same part number as on GT350). I pulled it out, sprayed it well with non-chlorinated brake cleaner and installed it back. The thing works like.a charm and no noises. Because I do not know how good a 10 year old valve is, especially after all the things it was doing, I ordered a replacement anyways. They are dirt cheap and a cheap insurance.
Thanks again to everybody for the help!
sox3
Newark, Delaware
George
Glad it was an easy and cheap fix.
