Help identifying engine noise
TX State
Unites States
2016 Shelby GT350 track pack
So iv noticed lately when holding RMPs steady at around the 2-3k mark I am hearing a noise. Any thoughts?
Rubyred17
Kentucky
2017 GT350
does it make the same noise if you are stopped and revving to that level?
TX State
TX State
Unites States
I haven’t payed attention to that when I give it a rev while stopped but I don’t think so. I will try it when I get home.
TX State
TX State
Unites States
I don’t notice it if I’m going through the gears or if I raise the rpm a little it goes away.
TX State
TX State
Unites States
Doesn’t seem to do it when I rev in gear. I did notice though the the exhaust is in quiet mode I can here through 3-4K RPM. Here are some more videos I took. In the video of the outside of the car I can hear it in the cab but it’s almost like you can’t hear it outside as much but at the 3-5 second mark of the video you can hear it faintly. The other one is reving not in gear. Also I noticed it seems like a vibration.
TX State
TX State
Unites States
Anyone with experience on the rattling with the plate between the engine and transmission; does this sound like that? I don’t think it sounds like piston slap to me.
Frank.Herbst
Denver, CO
Frank
2019 GT350
I had the trans to engine plate rattle. It sounds more like a vibration related noise than an engine knock. If your not sure of the difference between an engine knock and a sheet of metal vibrating, maybe see if you can find someone local to help.
hp1000
SJ
17 GT350
check you exhaust hangers, especially in the rear under the diffuser
TX State
TX State
Unites States
It doesn’t sound like an engine knock at all. It’s more of a vibration noise just seems to be coming from the engine bay or that area.
Txclyde1
Richmond,Texas
2015 GT350#43
TX State
TX State
Unites States
TX State
TX State
Unites States
Just had a friend lightly rev it while I was standing outside and I couldn’t hear it. I don’t know why it’s so hard to capture it on video. I seem to only here it while driving at a steady rpm.
TX State
TX State
Unites States
This is the best video I could find of what it sounds like.
matmar
Houston, TX
matthew
2018 GT350
Did you ever get this problem clearly identified? My 2018 does the same when 'not under load'.
I've had this issue before with a built motor in my 03 GT. The cause was the piston connecting pin holes were out of tolerance. I.e. the hole to place the pin in was larger than the pin itself. It was a defect in the forged pistons i purchased. The result was chatter in the cylinders when not increasing or decreasing RPM's.
