HELP MANDERS Fix His Clunk
Discussion in 'United Kingdom' started by Manders Mustang, May 3, 2018.
  1. OP
    Manders Mustang
    Manders Mustang The Boss
    First Name:
    Vehicle(s):
    2016 Race Red Ecoboost
    Dec 3, 2015
    Birmingham - United Kingdom
    13,073
    2,442
    Garage Profiles:
    Rating:
    100%
    2   0   0
    Well that's why i'm maybe swyaing towards alignement incase it's something rubbing and the uneven surfaces are pushing up the tyre in a weird way.
    I'm only thinking it as all 4 tyres were new and that side is about .2mm down on the other side.
  2. hinch
    hinch Well-Known Member
    Vehicle(s):
    Sideways
    Sep 15, 2016
    uk
    2,735
    657
    0   0   0
    would hardly call that excessive wear if you do more lefts than rights it can cause that level of additional wear so its fine. i'd have someone with a clue actually strip it down properly and check all the bushes etc not just the suspension/alignment.
    Prodrive is just down the road https://www.prodrive.com
  3. OP
    Manders Mustang
    First Name:
    Vehicle(s):
    Dec 3, 2015
    13,073
    2,442
    Garage Profiles:
    Rating:
    100%
    2   0   0
    My issue with "paying" someone to do it, is it could take 1day, it could take 10, it could be a case of trying loads of things and hoping they fix it, it could be a case of trying one thing.
    The risk that this ends up being a huge chunk of money reallllyyyy worries me.
  4. Centurion07
    Centurion07 Well-Known Member
    Vehicle(s):
    2015 GT
    Mar 9, 2015
    Hampshire, UK
    3,049
    912
    0   0   0
    I'm with Hinch. The chances of it being alignment-related are miniscule.
    What the hell are you using to gauge a 0.2mm difference?! Your penis? :D
    Vertical links are a worthwhile upgrade regardless. I noticed the difference immediately once I fitted mine. Firms up the rear nicely but not in a harsh or unwelcome way.
  5. OP
    Manders Mustang
    First Name:
    Vehicle(s):
    Dec 3, 2015
    13,073
    2,442
    Garage Profiles:
    Rating:
    100%
    2   0   0
    No you spunk trench, i used your boyfriends.
    Ford did it with a tread meter when it went in last week
  6. hinch
    Vehicle(s):
    Sideways
    Sep 15, 2016
    uk
    2,735
    657
    0   0   0
    well how much will a tank of fuel in a 50% mustang be quick blitz up the m1 and i can get it on ramps and take a look
  7. OP
    Manders Mustang
    First Name:
    Vehicle(s):
    Dec 3, 2015
    13,073
    2,442
    Garage Profiles:
    Rating:
    100%
    2   0   0
    I'm up in sheffield today, where abouts are you bud?
  8. Chappers
    Chappers Well-Known Member
    First Name:
    Greg
    Vehicle(s):
    Mustang GT 2017 - Magnetic
    Sep 11, 2017
    Sutton Coldfield, UK
    398
    67
    Occupation:
    Rail OLE - Technical Director
    0   0   0
    Make sure you take lots of pics/vids :thumbsup:
  9. Burkey
    Burkey Well-Known Member
    Vehicle(s):
    Feb 9, 2016
    Australia
    2,729
    1,402
    Garage Profiles:
    Couple of things.
    1. They checked the tension on the lock rings right? I mean, that’s THE most frequent cause of clunks on BC/Pedders/Airlift stuff, period.
    2. Even though you’ve proven the links, you can spin them around if you’d rather not have to worry about them rubbing. Airlift actually tell you to do this when using airbags. Eg. Mount them outboard rather than inboard.
    3. Please hurry up and find it.
  10. OP
    Manders Mustang
    First Name:
    Vehicle(s):
    Dec 3, 2015
    13,073
    2,442
    Garage Profiles:
    Rating:
    100%
    2   0   0
    1. Yes. But i'll get it up tonight and smash them with a mallet again to make sure they're still tight (both rings)
    2. You mean mount them ouwards, I mean, I could look into doing it, not sure it'll fix it though?
    3. You're telling me!!!
  11. OP
    Manders Mustang
    First Name:
    Vehicle(s):
    Dec 3, 2015
    13,073
    2,442
    Garage Profiles:
    Rating:
    100%
    2   0   0
    2. You mean mount them ouwards, I mean, I could look into doing it, not sure it'll fix it though? as it still clunked when removed
  12. Gibbo205
    Gibbo205 Well-Known Member
    Vehicle(s):
    UK 2015 Mustang & BMW E46 M3
    Jan 23, 2015
    UK
    6,796
    2,207
    0   0   0
    Did you try process of elimination yet?
    As you seem to be struggling to find this I would:
    1. Refit stock rear dampers.
    2. Remove front anti roll bar and drop links
    3. Remove rear anti roll bar and drop links.
    If it still clunks, you'd ruled out a lot by doing the above and as it seems 100% in the rear and if it still does it after removal of those, then remove all the other modifications in the rear and go back to stock, if its still doing it then either a stock bush is failed or there is an issue with the differential.
  13. acull2000
    acull2000 Well-Known Member
    Vehicle(s):
    Mustang
    Dec 7, 2015
    UK
    200
    36
    0   0   0
    Any updates Manders, have you found it yet? :shrug:
  14. OP
    Manders Mustang
    First Name:
    Vehicle(s):
    Dec 3, 2015
    13,073
    2,442
    Garage Profiles:
    Rating:
    100%
    2   0   0
    Like heck have I. I've got this weekend free i'll have a mooch at it then. Going to actually check the tightness of everything up front as well to see if that's part of the issue. :shrug:
  15. Chappers
    First Name:
    Greg
    Vehicle(s):
    Sep 11, 2017
    398
    67
    Occupation:
    0   0   0
    as silly as it sounds could it be a tyre buldge? I've had this before and there was a small buldge in the tyre on the inside so you couldn't tell unless you took the wheel off...
    this caused a random thud when i caught it on uneven road...
Loading...
Share This Page
