Help identifying annoying sound
fpa1974
GA
'19 GT350R
So I noticed recently that I started driving with my windows down (summer is over), an interesting noise. Only when taking a right hand turn in a sporty fashion I get this 'flip-flip' sound (like a pice of paper or tinfoil is hit with something at a certain frequency. The frequency changes with speed (take the corner faster and the 'flip-flip' sound frequency goes higher). The frequency seems to match wheel rotation (if the wheel would hit something once per revolution).
My theory is that something like the axles, or driveshaft has a piece of paper on them or something along those lines.
I will put my car up on ramps this weekend and look but I was wondering if I were on the right track or has anybody else seen this or has ideas what to look for.
Thanks!
MrCincinnati
Cincinnati
2017 GT350R
Thanks!
Sounds like you're on the right path
Tank
9/11 - Never Forget
Above the Notches
G0853
Annoying sound???
[ame]
Apologies but Icouldn’t pass up the opportunity....
Good Luck, hope you find out the cause and that it’s an easy fix and if not, it’s covered under warranty:cheers:
fpa1974
GA
'19 GT350R
Annoying sound???
Good Luck, hope you find out the cause and that it’s an easy fix and it not, it’s covered under warranty:cheers:
Warranty technically should cover this I agree - but I do not see myself going to the dealer and tell them to take fast right hand corners and diagnose. That is a waiver to abuse the car while 'diagnosing' (and yes they have done worse with less reason).
kairojya
Dallas, TX
www.youtube.com
Kyle
17 GT350
I sometimes notice a similar noise and assumed it was the floating brake discs. There's a certain road where I always here it as I'm going around a turn that has curbing. I figured it's easier to hear as the wheels/brakes are near the curb and the noise is bouncing off. I've heard it on both my 2016 and 2017 and assume it is normal.
SVTinAR
Arkansas
2017 Shelby GT350, 2003 Lightning & ERA FE Cobra
I think a brake pad(s) is a good possibility. You may have some glaze on a pad contributing to it. If it really bugs you, you could try pulling the pads and sanding them before re-installing.
fpa1974
GA
'19 GT350R
Pads could make noise similar to what I have but I just do not think in my case it pads because of the nature of the noise (mine is more like flip as it a piece of paper hitting a solid object - brakes should be more like grinding, scratchy noise).
I just do not know to be honest. I will check my pads as well.
DocWalt
SE PA
GT350
I am pretty sure this is just the pads catching the holes in the rotors and making noise. There's a tiny bit of hub flex and it's enough for the rotor to push against the pads. I had the same noises on my BRZ with the AP Racing BBK (has tiny slots).
  • Like
Reactions: TDC
fpa1974
GA
'19 GT350R
Car is on ramps and I checked a bunch of things. I could not find anything obviously wrong. I am starting to agree that It must something with the pads, rotors, brake shields maybe.
wildcatgoal
@sirboom_photography
TBD
^ This.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Rotors are never true straight. There is always some tolerances. It's the rotor slightly rubbing the pads. Normal but can be annoying somtimes.
  • Like
Reactions: TDC
TDC
Long Island
Just started hearing this for the first time tonight though it makes the sound when driving straight. Recently had my front pads replaced and back from a weekend track event. I don't see anything under the car to make the flap sound.
Never heard this before after nearly 2 years of ownership.
DocWalt
SE PA
GT350
That's interesting. I notice it much more after doing an autocross... It made no noise today and I've just been commuting back and forth with no autocross since October 1st.
