Help choosing a BOV / bypass valve
BoostedYote11
Illinois
2011 Mustang GT
2011 mustang GT running a Novi 2200SL.
Have the stock bypass valve currently and getting major flutter after WOT pulls so I'm looking at replacing the unit so I don't wreck my blower.
I've been searching for YouTube videos but it's limited and I'm not getting a great idea of what they all sound like.
I'm considering the BV57, sounded good in one video I found, but not sure if it'll work on Low boost applications (I'm running 8 PSI).
So I am looking for recommendations and /or videos of BOVs you guys are running.
I prefer a more "sleeper car" approach, I really don't want the car making a high pitched whistle under low throttle.
I'm ok with it being really loud after WOT pulls because at that point it's too late anyway ;)
You guys have any recommendations? Example videos?
Thanks in advance.
Therealmattlex
Mn
2015 mustang gt
I had great results with the Tial Q I ran. It was really loud all the time. I'm not sure if they're all that loud, but no surge.
ToughSpecs
Pennsylvania
Tim
Edge
BV57 is a good option if you don’t want it too loud. Yes, it gets louder as the boost builds when you are off or partial throttle, but it’s nothing bad.
BoostedYote11
Illinois
2011 Mustang GT
That's good news and seems to line up with what I heard on some videos. Can it be used on my setup only running 8lbs or do they have a minimum?
Jackson1320
Jaxson
2015 mustang gt
I have a tial Q on my procharged 15 mustang. I did use a supercharger spring in it.
I have seen people use the knock off tial bov on eBay and it works perfectly. Not sure I want to use it but it does work
BoostedYote11
Illinois
2011 Mustang GT
It will work fine running 8psi.
I emailed vortech this morning when I made this post and they replied "The BV57 is more for race applications and not for under 15 psi."
But I got the distinct feeling whoever replied doesn't know their ass from a hole in the ground? Are you sure it will work? I may call tomorrow and see if I get someone who can confirm.
Therealmattlex
Mn
2015 mustang gt
Any large BOV with the correct spring in it should work. On a supercharged car the BOV should be open when almost any vacuum is present. The only issue I've had is with BOVs that are to small and can't dump the air quick enough when they open, I've gotten compressor surge. I can't imagine dumping to fast could cause any issues when.
cbrtrx
tampa fl
2016 mustang gt
Yes it will work fine.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Bv57 is freaking huge, make sure you have the room. Procharger red race is more compact.
mangosmoothie
Flagstaff
Casey
2019 Boolet
great to hear. I ordered a knockoff tial to try out and see if I like the sound. if it works… might as well keep it. Seems low risk to try lol
