Heel-toe pedals
tj@steeda
Timothy
Anyone that is interested or on the fence, we have 15% through tomorrow!
Best Regards,
TJ
altjx
GTFO_0036 | 1337 h4x3r
Atlanta, GA
www.altonj.io
Alton J.
2017 Race Red GT350
Considering getting some of these. I wish I had ordered some sooner so I could practice this before hitting the track on Sunday.
Random stupid question -- with wider acceleration pedals, does it take some getting used to? I find that in my gf's stang, I can feel the accelerator on the corner of my foot when pressing the brakes just slightly. No one accidentally hit brakes and accelerator when coming to a stop eh? Lol.
BTM
I redline at 11,000rpm
Lincoln, CA
Thunder Roadster GT-R / ST3
Yes, it absolutely takes some practice and careful foot/leg positioning to not accidentally hit both with your foot. I have the Steeda h/t pedal and Garageline spacer, and my gas and brake pedals are on the exact same plane and right next to each other. Just one of the reasons why I don't let anyone else drive my car...
But once you're used to it, it's easy, just becomes second nature. Only challenging under really critical threshold braking where the brake pedal is pushed further down than normal, of if you're wearing clunky shoes, like work boots.
But this is exactly why most cars don't come stock with good h/t pedal positions- liability for "unintended acceleration "
altjx
Atlanta, GA
www.altonj.io
Alton J.
2017 Race Red GT350
Gotcha. Makes perfect sense. Very interesting! Thanks man.
Berstuck
Northern California
Brien
2015 Ecoboost Premium PP M/T Competition Orange
Honestly you just learn to brake with the left side of your foot. With the brake fully depressed I'm revving the engine maybe 300 to 500 rpm's. Nothing that will actually affect your driving in any way. Plus it allows me to heel and toe with ease.
altjx
Atlanta, GA
www.altonj.io
Alton J.
2017 Race Red GT350
Talking about with the actual heel toe pedals right? Do you guys also find yourself jerking the brake (applying more/less pressure) while heel toeing? The first time I tried without the heel toe pedal, braking was a little less smooth and weird for me. Still planning on getting this pretty soon though.
Berstuck
Northern California
Brien
You won't apply even pressure on the brake pedal the first few times you drive it. It will become muscle memory rapidly though. And yes I use Steeda's heel and toe gas pedal. Also some leeway in mounting it, maybe a half inch either way. I mounted all the way to the left, and it works for me with a size 8.5 shoe.
altjx
Atlanta, GA
www.altonj.io
Alton J.
2017 Race Red GT350
Gotcha!
Keith_PDX
Portland, Oregon
2017 GT/PP
I went with the Steeda pedal, because price. Also .5 inch spacer. It's almost too much spacer, but works out well with my size 8.5 shoe. Anyways, I can now heel and toe the car while driving home from work, it's great.
What are people using to space out the pedals? Saw the GarageLine spacer but, to me, if you're going to drill on a new pedal cap then you have other options (between OEM pedal and Steeda) that might be cheaper? Looking to see if someone already has a proven solution rather than figuring it out the hard way myself! ;)
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Biggest reason I haven't done anything like this is because once you're braking hard enough (like at the track), you don't want the step-over height to be compromised.
higdominator
Central Oklahoma
2016 GT PPP
A local ACE hardware or similar should have some nylon/aluminum/steel spacers that will fit over the studs. a 10mm spacer is what it took for me, however I have really narrow feet when they are squished in my driving shoes and I prefer more meat on the brake pedal, thus I use much less of my foot to tap the gas. With my setup I just have to do a very minor roll to rev it.
My right ankle has much less flexibility in that direction as I took a rattle snake bite to it years ago and it's never been the same.
For me the spacers weren't a necessity, but more of a luxury.
pstoppani
Redmond, WA
2017 GT PP
+1 on Steeda pedal + Garageline spacer. Perfect setup, and you can fine-tune the exact placement of the Steeda pedal, because you drill the stock pedal backing piece to mount.
I have the same setup; very pleased.
I prefer no grip on the gas pedal. The brake and clutch on the other hand, I like some grip.
pstoppani
Redmond, WA
2017 GT PP
The brake pedal in these cars moves so little under braking that the heights are not compromised.
