bam88
- Jun 18, 2015
- Alberta, Canada
- 2017 Ecoboost PP
Differences between all of them come down to the size of the core. Size directly effects pressure drop and max flow. Larger the core the more it will flow however you will have a larger pressure drop. Pressure drop to the untrained eye will look or feel like lag as it takes the turbo more time to to fill a larger volume with the same pressure of air. If you plan to stay under the 550whp range then MAP and Mishi are the better choices as there will be less pressure drop and the turbo will be more responsive. End tank design also plays a factor in pressure drop as you want air to enter and exit as smooth as possible while also utilizing the entire core.
