Headgaskets for big power guys?
Nctong01
Kentucky
'17 Big Turbo Mustang Build, '17 Turbo Silverado, '16 AMG GTS, '99 Turbo Integra
It seems like every sector of car tuning depending on car brand has it's own preferences on headgaskets for bigger power...a lot of guys swear by OEM gaskets, others aftermarket. Just guys running higher boost levels with coyotes, is it worth it in your experience to go aftermarket or will the oem gaskets suffice?
engineermike
La
2018 GTPP A10
Generally speaking, multiple layers are better than single layer. Stock coyote is 3 layer and gt500 is 4 layer. Cobra jet is also 4 layer. Cometic mostly makes 3 layer but they do make a 5 layer for Gen 2, which isn’t compatible with Gen 3 FWIW.
The additional layers give the gasket more elasticity on a microscopic level, which helps absorb abnormal combustion impact to protect hard parts. Some of the LS stuff is 7 layers and I’ve heard of even more than that.
Nctong01
Nctong01
Kentucky
I appreciate the input. I was leaning towards cometic as is so I will check out the 5 layer option. It also looks like the offer a 4 layer as well in stock compressed thickness which I believe should be .4.
Jackson1320
California
Jaxson
2015 mustang gt
What are you calling higher boost? I run 18psi and I don’t consider that high boost. Are you running studs?
Nctong01
Nctong01
Kentucky
Yessir. Anywhere between 25-30 pounds.
Nctong01
Nctong01
Kentucky
Gt500 hg here, 4 layer, .036 compressed. 1300whp, 26ish psi.
I ended up going with a 3 layer GT350 cometic just for ease of access. I think it'll be adequate but we'll see. By off-chance, do you know if .4 is stock uncompressed thickness?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
No idea on that.
