what kind of power are you guys putting down with your forced induction 18's and 19's?
Offaxis
Levittown N.Y
Mustang
Im putting a twin turbo kit onto my 2018 mustang but ive been seeing a few posts now that these motors aren't holding up as well as the 15-17 coyotes. Is this true? my 2017 is making over 900 on the stock motor for over a year. now im getting worried with the posts of pistons breaking on the gen 3's
kidamer
ohio
2018 mustang gt 10 sp auto
Im putting a twin turbo kit onto my 2018 mustang but ive been seeing a lot of posts now that these motors aren't holding up as well as the 15-17 coyotes. Is this true? my 2017 is making over 900 on the stock motor for over a year. now im getting worried with the posts of pistons breaking on the gen 3's
so how many is alot? 2 or 3 or alot like 100's?
Offaxis
Levittown N.Y
Mustang
I guess I should say ive seen a few posts of pistons breaking and rods coming out of the blocks. I guess in the big picture its not that many out of all the mustangs sold but im not sure how many forced induction guys have had a problem.
Mustanggt5.02011
2019 Mustang GTCS
One thing to keep in mind with forced induction on a high compression motor is to keep the timing low. Its ok to run 12 PSI but once you start adding timing its a ticking time bomb. I'm only running 7 PSI and timing is locked at 17 degrees on E85. If I were on 93 I wouldn't run more then 10 PSI and 13-14 degree's of timing. Thats just me, and I daily drive my car 64 miles everyday to and from work. I'd rather be conservative then have to replace a motor. Still a fun car at 700/700.
engineermike
La
2018 GTPP A10
Ok I watch this forum pretty close and I’ve only seen one reported failure of a 2018 engine and it was a piston failure at 1000 rwhp on a mustang dyno. Can you link me to more?
There were reported failures of 2015-17 blocks at 850+ hp but 2018 added reinforcement in the weak area. The 18 also got a viscous damper which should help with the opg failures.
Rjames18
Houston
RJ
2018 Mustang GT A10 Orange Fury
Mine made over 950whp. Beat on it almost everyday! Probably could've turned it up more but it was 3am and I'm sure the houses not too far away weren't very happy
Mustanggt5.02011
2019 Mustang GTCS
People are not advertising they popped their motors. From shop to shop the owners talk. I know of 2 within the last 4-6 months that have popped and rebuilt their motors. These were brand new 2018 Mustang GT's with power adders.
engineermike
La
2018 GTPP A10
Ok but the OP specifically mentioned posts about popped motors. I have only seen one.
Do you have any details on the 2018 failures? Power levels? Fuel? What broke?
pro 5.0
Canada
2019 Mustang GT
My 2015 made 912 @ the wheels on E85, 15 psi and 18 deg timing stock motor with opg/cg. I have a 2019 on order and am going to put everything from the 15 onto the 19, undecided whether or not I'm going to build the motor yet or not. With the sleeves removed in the 19 that should remove that weak link and the rods and pistons should be able to take the same power. The ticking / knocking / wrist pin / cylinder scoring is what has me worried about using the stock parts.
pro 5.0
Canada
2019 Mustang GT
Then you have the Midnight Performance 2018 TT GT running 8.60's @ 160 + on a stock un opened motor, not even opg / cg using a 2 step as well. Really makes you wonder if the new fluid filled balancer is the ticket to keeping the stock opg / cg happy as a 2 step is violent on everything including the timing components.
Rjames18
Houston
RJ
Don't believe everything the internet claims...
Rjames18
Houston
RJ
Yellow badger is only one I know of.
There was a guy that installed an old LPF kit he had on his 1st gen s550 installed onto his 2018. They didn't hook up the wastegate lines I believe and it spiked around 18+lbs... Needless to say his motor didn't last. That would've put him at well over 1300+ to the wheels
pro 5.0
Canada
2019 Mustang GT
I read that they are on a 3rd 10r80 which is believable since it slips as for the stock motor unless someone actually witnessed it themselves it's all speculation. Seeing that Hellion has made over 4 digit power on the stock sealed motor one would think it is possible, are you implying that the motor is not stock as claimed ?
Rjames18
Houston
RJ
Being from Houston where they are I hear a lot of things. Whether they are true or not I'm not certain.
The hellion car made 4 digits with a 1.27 correction factor. Realistically it would've made about 950 which is where most twin 18's are sitting at, including myself.
I'll be out at the track next weekend to see just how fast I can get mine to go. So far on only 9lbs it ran 9.345 @147mph.
