Guess drivetrain noise?
VictorH
South Carolina
Victor
2021 Mach 1
In the past few days have noted a driveline noise that is getting louder by the day. It's not that loud so wouldn't be heard on audio or video recording. The characteristics as follows:
1) It's a muted tapping noise coming from the back, my guess is driver's side
2) Tapping frequency goes up with speed and less when slowing down.
3) Will make tapping noise in gear or coasting in neutral.
4) slightly louder under driving load compared to coasting
5) I can't reproduce any noise with the car up on lift, in neutral and spinning the tires (either side) by hand.
6) The drive axles don't have any tears or rips in the boots and the "slop" in the axles from side to side is about the same on right and left (I am most suspicious of a CV joint but don't know how to prove it)
I tell you what it's not:
1) Brakes, calipers are tight, pads are new and no odd wear patterns
2) Pretty sure it's not a suspension component particularly given the characteristics above
3) Tires/wheels, new less then 300 miles, new rims too, don't see any obvious damage and the car does NOT vibrate at speed
Bulldog9
Northern Virginia
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912, 1989 Porsche 944S2
Rock in a tread, screw or nail in a tire that is not deep enough to leak air?
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
if it just started with the new tires/wheels then it is probably heels/tire related.
Loose tag on driveshaft flapping around?
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
Muffler/pipe hitting swabar?
VictorH
VictorH
South Carolina
Victor
2021 Mach 1
Never said it started with new wheels/tires. Tires are new no screws, rocks or nails and that's not the type of noise anyway.
Probably wasn't very clear about the character of the noise. It's perhaps more of a deep, rumble type of tapping., NOT a soft clicking like you get from a nail.
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
Perhaps differential bushing, allowing pinion angle to change?
TopJimmyCooks
Raleigh, NC
James
2017 GT Prem PP; 2019 EcoBoost Prem
Broken muffler hanger? After everyone else's suggestions there's not much left.
VictorH
VictorH
South Carolina
Victor
2021 Mach 1
Thats my personal initial guess.
Why? It's a new car, 7,000 miles and the underside still looks like new, no hanging muffler(s).
Anyone have experience with a bad CV joint? What do those sound like?
The wheel bearings, I checked again tonight, they are nice and tight, no play whatsoever and rolls smoothly.
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
Because they're mounted in rubber and can move around or a hanger can be bent slightly and not be noticed unloaded (on lift)
Being a 7k car, it's a dealership trip.
VictorH
VictorH
South Carolina
Victor
2021 Mach 1
Well, put it on the lift (at home not dealership [yet]). Ran the car in first and second gear, just at idle and then with the brakes dragging just a bit. The whole driveline is completely noiseless.
No clunking, no tapping noises. Looked underneath while running and don't see anything wobbling or out of round.
The muffler hangers looks good, everything on the exhaust looks to be tight and as it should be.
Going to take my neighbor who is retired mechanic and has helped me sort out a few issues that were tough to figure out, for a little ride tomorrow. If not luck, then might just have to go to the dealer.
VictorH
VictorH
South Carolina
Victor
2021 Mach 1
PROBLEM IDENTIFIED- It's the right front hub wheel bearing! There's no slop whatsoever, it's completely tight but when you spin the wheel it makes a muted popping noise. All the other wheels are completely quiet.
S550VIN54
Raleigh NC
Stephen
2021 FJG Mach 1 HP
Oh wow! I thought that had been ruled out. Good to hear! Glad you were able to resolve this matter.
cerbomark
TN
Are s550 know for weak wheel bearings ? Or is this a one off?
