GT500 Titanium Lug Nut Solution
50 Deep
Signature Wheel Ford Rep
Gold Sponsor
Sacramento, CA
www.signaturewheel.com
2017 GT350R
Well, it all starts with a problem. For a while now many of the GT350R owners switching to aftermarket wheels found themselves dealing with the extended front studs protruding out much further than the rear studs. For the R It all stems from the pad used on the OEM Carbon Fiber wheel. I suspect the front of the GT500 will also include extended studs to accommodate the carbon wheel design. The pad is much thicker up front and takes up the space from the extended stud. All aftermarket wheels use a thinner pad, so this is an issue for any enthusiast owner switching away from the OEM wheel. This also happens with GT500/GT350/S550 owners running extended front studs. When you swap to an aftermarket wheel, that stud requires you to run an open-ended lug nut. The end result is front and rear lug nuts that no longer sit at the same depth as OEM. Even from the factory the GT500 lug nuts sit deep inside the lug pocket, and at a different depth. For many it is aesthetically unappealing, and causes difficulty finding a lug nut to run front and rear.
Since I started with Signature Wheel I have had several customers asking about lug nut options for the extended studs on the R. As time went on it was discovered that in many situations the OEM lug nuts would distort the chrome cap, swell under heat, or had too large of a head to work on aftermarket wheel setups. The end result was the development of titanium lug nuts to solve these concerns. You can read in depth on all the benefits of the titanium, but the main points are the reduction in weight, corrosion resistance, increase in strength, and resilience to heat swelling.
What was developed is intended to be the last lug nut you will ever need. These Exhibitions Of Speed titanium lug nuts are specifically designed to solve all of the issues S550 enthusiasts have ever had. Specific lengths are used front and rear to allow the lug nuts to sit at the same depth. Open ends are employed to work with any brand M14 stud you plan to use on the car. A raised engagement point ensures you don't demolish the inside of you lug nut recess trying to access with a deep socket. Standard 19mm hex heads ensure proper clearance at the lug nut wall, and eliminate the need for any specialty sockets. A 50% reduction in weight makes sure you are totally racecar. Complete sets of short lug nuts can be special made for those seeking to run square wheel setups with spacers.
These lug nuts were specifically designed to work with our Signature Wheel. Nothing like these exist on the market for the S550. Much work from several awesome partners brought these to being because I love you guys, and nobody will ever love you like I do. These have also been shown to work will with other brand wheels, but you cant go putting ketchup on steak. Cost has been kept down to $430 shipped for these, and if you look around at other titanium brands you will see it is well placed in the market. We have had roughly 200 sets go out over the past 3 years and never had an issue. Street them, track them, off-road them, or use them to impress girls at the bar when you show how light your nuts are.
I build small batches (30-40 sets) approximately twice a year so these are fairly rare bids. More are built according to how many place 50% deposits to have them ordered. I am planning a new batch for March and they take about 60 days to complete. They are all raw titanium to keep costs down on small batch plating/coating, plus they are corrosion resistant. Some black caps are in development, but not quite ready for market.
If you have questions please ask, and you can also see the existing thread on them linked below in the GT350 section. If you are interested in the next batch please comment below or DM me your email address.
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Some stand alone pics of the titanium setup and prototype caps
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Few pictures of the OEM base GT500 wheel with the factory and Exhibitions Of Speed lug nuts. Great option for OEM wheels too.
protraxduner
OK
2020 Shelby GT500 Race Red
Cost?
Do they accept powdercoat/paint? Have never dealt with titanium.
Are the end cap/inserts plastic? just press fit in?
thanks
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Ill take em.
You’re in!
Cost?
thanks
I haven’t delved into the coating process for the titanium. A chemical process would be better to prevent scratching or chipping though.
End caps are 3D printed, but not sure of the material. Still doing some R&D on those before release.
couple more shots of them in action
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Gents,
The next set of Ti lug nuts is in production now with a 45-60 day lead time. I am doing a run of 30 sets, with 18 sets spoken for already.
Please send me a DM if you want to get in on this batch. The next set will likely be built sometime in the fall.
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Hey everyone. Quick update.
The May batch is arriving to me today. I will have them packed up and shipped back out to all those waiting Thursday and Friday via USPS.
The next batch is on target for the end of July completion. I have about 15 sets left available. Added in a few all short sets for those with stock carbon wheels, or running square rotatable track setups.
cheers!
Tomster
Beware of idiots
Tom
They look great!
Normally Ti is anodized.
Yes, I was after him to do that a long time ago. I dont know if he ever got around to it.
So on another note, would you use them for the track? My concern is that an engineered torque specification is not available. Since you need to use lube due to dissimar metals, the OEM torque of 150 +/-15 is no longer valid.
Thoughts?
Twisted O CFTP
Orlando,Fl
Alan
2020 GT500 CFTP
cheers!
Hey this is an awesome mod can you get these is anodized or pvd coating also were do you put the order in
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Just PM me your email address and I will add you in.
You can definitely have them anodized or or coated. I don’t do it on my end as small batch coating gets expensive. Trying to keep the cost on these as low as possible.
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Feels like I just shipped a bunch of cocaine, considering how dope these all are....
