Erik427
- Oct 5, 2014
- Huntington
- 1979 Mustang
So giving a Coyote the 5.2 bore would allow them to fit.....? Destroking the 5.2 would be a winner in my book. Better rod to stroke ratio. Less kenetic energy do to slower piston speeds....and slightly less over all mass. The shorter stroke would have been easier to balance too. Wonder why Ford chose the path that they took?They said they look like they bolt up but the valves will hit the cylinder walls. The valves in the Voodoo were spread further apart so... while it will directly bolt up, it will not operate.
A shorter stroke is the only option...
Looking into this now, there is no Camaro answer to a FPC V8 GT350. A pushrod engine floats the valves without extensive valve train work. A DOHC is badly needed at GM. Every minute they don't invest in V8 OHC technology, they fall farther behind. They can't just pour on the displacement anymore, this will be a huge challenge for them.
If the Power to Weight figures were true, the GT350R could be just under 3550lbs. DI adds about 3-4lbs to the engine, a smaller crank will help a tiny bit... I would like to see them shed the GG Tax with a short stroke Voodoo (Voodoo Child) so they can make use of that $1300 elsewhere.
The Base GT350 could give the z28 some trouble. Eliminating shift points during a lap is a big deal.
