GT350 FORScan Tweaks
milner_7
Hamilton Ontario
www.highdefinitionautodetail.ca
2016 Shelby GT350 Deep Impact Blue
If you press the start button without engaging the clutch you can press sport mode and then start the car in Sport Mode.
datadatum
JAX
'18 GT350
Ok, done!
I have the R splash screen, disabled the ANC, activated NAV in motion, no double horn upon exit with key, and no seat belt reminder.
Easy peasy. :)
datadatum
JAX
'18 GT350
So after a few miles without the sound enhancement, I have to say I'm very surprised at how LOUD the piped in sound was. While the car doesn't sound as "cool" without the loud exhaust sounds in the cabin, it sounds much more natural. Still sounds great, just not as loud. And I can hear the radio or talk to a passenger.
Stang 19
Ca
2020 GT500 Ford Performance Blue
AWE Tuning makes a module that allows us to run the valves open or closed without the car deciding what it wants to do. It still retains the ability to open and close the valves at the push of a button, yet it wont open them above 2/3 throttle or close them in 6th gear. It also doesn't throw a CEL or lock you out of drive modes. There's a great thread on the topic by @GT350Brakes.com you should check out if you want to get around this feature.
Received reply from AWE: their device does NOT work on GT 350’s. Per them.
MikeMM
VT
2021 GT500 on order
Stang 19
Ca
I can't believe I didn't even consider looking for that one! Next time I see him I'll take another look and see what I can find.
What do i need to do to load the program onto my laptop? I already have a bluetooth dongle. Also, is there an App that does the same thing?
RAUSP
Austin, TX now Germany
Rudolf
2018 GT350
I'd need your help. I programmed my IPC and found a funny thing after I compared the Ford Module Build Data with my original Backup-File. Can someone please check the 720-01-01 register? Best on a 2018 GT350.
Background about the 3rd digit in first block:
The downloaded data say for 720-.01-01 -> 8C0B 1064 6094
Now I am not sure that I didn't made a mistake before I saved the data but my backup says
8C1B 1064 60A4 (3rd digit is a 1 instead of the expected 0)
I tried both values but can't find a difference.
THX 138
Brownsburg, IN
2016 GT350 Track Pack, 2002 Porsche Boxster S 3.8L
Just a quick thank you to Epiphany for starting this thread, and I wanted to provide an update as well. My OBDLink MX+ Bluetooth came today ($10 off on Amazon currently). I downloaded the most recent version of ForScan (Version 2.3.19, updated 12/24/2018), registered with the forum, got my trial license key, plugged into the OBDII port, and paired the OBDLink with my laptop. Bingo! I'm in!
The latest version of ForScan has added a simple "enable/disable" toggle in the BCM module for "Double Horn Honk While Running," so you no longer have to go into the AsBuilt data and change the values manually. Worked like a charm... No more Double Horn Honk when I get out of my car to check my mail, etc. :)
RAUSP
Rudolf
2018 GT350
That double honk function was already there and is not new.
THX 138
Brownsburg, IN
It's new since Epiphany's original post. See the pic below, from Page 1. I'm sure the feature was added sometime during the intervening 41 pages... :rolleyes:
ZX3ST
STL
2018 GT350, Kona Blue, J3116
My as-built for that register is 8C0B 1064 6094
What are you trying to change?
RAUSP
Rudolf
2018 GT350
Thanks, I changed it back to that value and it's all fine.
Afterwards I changed the intended value to have the Chimes on ACM only:
XXXX XXX0 XXXX and that works also.
NoXiDe
GA
GT350
I'm in BCM and I don't see the following values: I've provided a screenshot of what I do see.
2015 / 2016 MY profiles on ForScan 2.3.19 show same data.
I'm going by the spreadsheet and also page 17 epiphany's steps.
BCM 726-32-01 0A01 0000 006B Entry Lighting Disable (Dark Car Mode) 2016 Track
BCM 726-32-01 0A01 0100 006C Entry Lighting Enable 2016 Track
BCM 726-41-02 0000 0001 0172 No Horn Exit When Running 2016 Track
BCM 726-41-02 0001 0001 0173 Double Horn Exit When Running 2016 Track
BCM 726-41-02 0000 0000 0070 No Horn Exit When Running 2017 Conv
BCM 726-41-02 0001 0000 0071 Double Horn Exit When Running 2017 Conv
Please view attached screenshot of my results. Any help would be appreciated.
JAJ
Vancouver BC
That's because you're in the wrong module - BCM is 726 and you're in 7B7.
Try BdyCM - it could be that some bright spark decided to relabel it in Forscan.
