Shelbygonewild
Does anyone have a source for the rivets that hold the splitter in place? How about exact rivet dimensions?
Never heard of the oil line recall work being performed from above !!!:shrug:No, I was having my oil line recall done and I thought that I would help the tech and myself by exposing the underside of the car. I pulled all the fasteners out only to find that the underbelly is riveted to the splitter as well. Come to find out, the oil lines are replaced from above with the simple removal of the air cleaner assembly. once it is removed there is a lot of room to get in there to work. I hope my mistake helps others.
Phillip
Phillip - you do not remove the rivets in order to remove the splitter. Those rivets are for a structural "section" that stays in place during installation or removal. Remove all the fasteners except any of the rivets.No, I was having my oil line recall done and I thought that I would help the tech and myself by exposing the underside of the car. I pulled all the fasteners out only to find that the underbelly is riveted to the splitter as well. Come to find out, the oil lines are replaced from above with the simple removal of the air cleaner assembly. once it is removed there is a lot of room to get in there to work. I hope my mistake helps others.
Phillip
