Going to the track? Traction control off?
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
So how is the traction control completely turned off ? I usually have it in normal mode and hold the traction control tab for around 6seconds and advance trac mode off shows but something when selected LC for launch control shows and other times rpm shows, so how should I do it the right way?
2-tone
Cincinnati
15 mustang gt m6
I have never used launch control. I shut advance trac off and run it.
Burnin4
Mooresville
17 GT350
Just press/hold up the tc button until the AT turns off, then you'll be good to go.
v8ter
v8ter
Typing...
EL PASO , TX
But doesn't it keep the traction control on at some degree still?
If I pull fuse 62 ,does the line lock still work?
Tommy V
Brookly park Md
Tommy
U dont want to use launch control because that still uses a little trac/stabilty control.Go into trap apps and u can turn off launch control.It has a little box and if that box has a check mark in it launch is on,no check mark and its off.If u pull that fuse no linelock,it disables abs.
Dbeast
2015 5.0 Mustang
I just went to the track to see how it does stock and I shut TC off and put it in the track mode. Everything stock including tires but I added 0.5 gal of e85 on half tank of gas and ran 12.542@112. Without half gal of ethanol I ran 12.696@112
My 60ft with stock tires on 19inch rim was 1.960. So TC off and Track mode worked for me.
I love how these cars run mid 12s stock now I got kenne bell on order and other mods to push this beast into 9s.
