Phlyguy
International SAR Pilot
- Jul 16, 2014
- Greensburg, PA
- Marc
- 2015 Ruby Red Mustang GT with Recaro Seats
Found this tidbit out while researching problems with the Getrag Chinese manufactured MT82 gearbox found in every Ford Mustang GT since 2011. Apparantly, when problems with the original Getrag MT82 started reaching complaints in the hundreds, the National Highway Traffic Safety Administration launched an investigation into the problems (which was later dropped...) after Ford sent out two Technical Service Bulletins (TSB 11-3-18 and TSB 10-19-4) relating to the complaints of hard shifting when cold, vibrations, noise, and ratcheting shifts. TSB 11-3-18 required nothing more than a servicing of the gearbox by removal of the transmission fluid and switching to Ford Motorcraft Dual Clutch Transmission Fluid (a ligher standard 75W gearbox fluid). Conversely, the Ford Motorcraft Transmission Fluid servicing charts were modified to include a notation that a "Friction Modifier" called XL-18 be added to all subsequent MT82 services (this notation and service item does not appear on the original TSB and the only reference to XL-18 is in the Transmission Fluid Charts under Note 6). XL-18 is used during the build-up phase of the transmission in China and it is assumed that both the QDC fluid as well as the XL-18 are both being used when the gearbox is delivered and mated to the engine and drivetrain. According to user reports, those folks that say they had their dealer service their MT82 gearbox with QDC and XL-18 reported significant improvement across the board, especially with cold shifts. I only bring this up because I suspect that there are Ford service reps. who have no idea that there is an additive that is required to go into the tranny during servicing that does not appear in the original TSB and I suspect does not appear in updated service manuals. In essence, and unless you looked at the Transmission Fluid Chart, you would not know about adding XL-18 to your MT82 Gearbox. Just thought I would pass this tidbit along...
