Kahboom
Kahboom
- Nov 28, 2014
- Cathedral City, CA
- 2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
Head gaskets went out, car is mixing coolant in oil, was eating oil for 7 months.
So tearing down motor to see what is reusable, heads should be good, replacing timing components, already ordered the following
MMR timing chain guides,
Boss 302R tensioners,
ARP timing chain and tensioner bolts,
MMR cam cap bolt set,
ARP 11mm head studs,
ARP Main bolts and side bolts,
MMR secondary tensioner plate,
MMR timing gear,
MMR crank timing gear,
MMR proboost head gaskets,
MMR secondary timing chains,
Ford Racing/GT350 timing chains,
JPC oil squirter block offs,
MMR High flow oil pickup,
New oil pan and gasket,
Don't know condition of the stock block so until it's pulled I don't want to order a rotating assembly, not sure if water jacket supports are needed for under 1200hp, currently using a gen 3 VMP blower. Also could not find a place that has the gen 2 block for 800.
Any advice on ring gaps or rotating assembly?
Was looking at modular head shops 1200hp rotating assembly.
MMR timing gear,
