Gauge Screen/Vitals Screen
bjblackout
Abingdon, Md
I was wondering has anyone bought an aftermarket screen of any type to keep an eye on things vital to the operation of the car. I don't want to do an Nguage yet as I am not putting a tune on my car yet. I have a screen made by edge in my F250 diesel that keeps an eye on different vitals of the truck. Has anyone used anything like this thats not an nguage or apillar gauges??
Brombones
Raleigh, NC
David
2019 GT Mustang PP1
You can still use an nGauge without having a tune, it will show all the diagnostics.
pyrophilus
Westchester, NY
'19 ShadowBlack GT Premium401a, 6MT, PP1, ActiveExhaust
I guess you can also get an old phone that you no longer use or an old tablet and mount that somewhere in your car, run bluetooth OBD2 connector and run Torque app.
One thing though, you cannot keep them plugged in becase some some BT OBDII connectors do not have sleep modes, which means it can drain the battery. There are some that have sleep modes. I think one of the models that is made by OBDLink claims to have sleep mode and apparently you can keep it plugged in all the time.
EFI
Masshole central
5.Br0
What's wrong with the info that is in the little screen in them middle of the dashboard? Are those not enough and if so what other things do you need to keep an eye on?
NoVaGT
Northern Virginia
2019 PP1 GT Kona
This.
JimC
Howell MI
Jim
2024 Mustang GT with performance package, magneride and A10
Only one gauge at a time, or a stack of information in small font that is hard to see with any sunlight and sunglasses on. And you can't configure the gauge list to what you want to see so can't get to everything that you might want to monitor
EFI
Masshole central
5.Br0
Unforutantely if you can't see those, you're not going to see any of the other options on the market unless you get the Tesla screen and link it up thru OBD2 in the Torque App.
JimC
Howell MI
Jim
But I could configure what I want with torque app.
What I would really like is to have separate boost and oil pressure gauges in a pod on top of the dash, like I had in my 2006 and 2013. I can then run the AFR in the center section. So far haven't found a gauge pod for the top of the dash though for the S550 (other than the very pricey Shelby one)
Zooks527
2019 KB GT, 401A, 6MT, PP1, S&S, MR, AE, B&O / 2018 Jeep Grand Cherokee Summit
Well, you could install the center dash trim from a PP car and add the EcoBoost Oil Pressure / boost gauge. Sure, full list for both items will run you several hundred bucks, but you can likely find a used gauge on eBay from someone who's changed his over to the GT350 gauge set and then chase the dash trim from a salvage yard, with AFR on display in the dash center.
