gtmiller1001
- Nov 28, 2014
- Houston, TX
- 2015 Mustang GT Premium PP
So I'm in Houston and it's usually not too cold here. I have a GT PP, so I have the two mechanical gauges above the radio. When it's cold outside (50* or less) and dark with headlights on auto the two gauges in the middle do not illuminate. Depending on how cold it is they eventually will after the car is warm, usually at least 10 minutes. It was 36* this morning and they did after about half an hour.
Weird thing is, if you go through the my color options none of them work on those two gauges but they do change the speedo/tach colors, BUT...when you choose white the speedo/tach go white and so do the center gauges... When it is warm enough it doesn't matter, all the my colors work properly on all gauges.
So basically conditions are:
Cold out
Headlights on auto and dark enough to turn lights on and illuminate gauges to nighttime setting
Center PP gauges don't illuminate unless white is selected
Anyone up north seen this where they are much colder than I am down here?
Cold out
