Front sway bar installation
Fjc
Michigan
2019 Mustang GT fastback
I've watched some videos, but now I'm looking for some feedback. How hard is it for a garage mechanic to get that front sway bar out, and get a new one in? I do have a QuickJack lift, but not something that'll get the car more than a couple of feet off the ground.
I'm seriously considering front/rear sway bars and new sway bar endlinks, but want to know if I'm biting off more than I can chew. Rear sway bar looks very easy to swap out, the front not so much.
Thanks,
WhiteyDog
WOOF!!!
Manheim, Pa.
I did mine myself, both front and back. So a mechanic should EASILY be able to install it.The front was a little tricky but jacked it up, took both front tires off, removed the stock sway bar out the driver's side, installed the thicker sway through the driver's side. Had the wife reach through the passenger side to help guide it as I pushed it through.
  • Like
Reactions: Fjc
ModularKid21
‘15 GT
It just takes some patience, you’ll get it. I removed the airbox to get to the driver side mount bolts. Other than that, just take your time. Another person, as mentioned above, to help guide it from the other side would be helpful, but not necessary
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
Did mine alone on jackstands. Front wheels off, air box out. I fished out the old sway bar from the driver's side. To install the passenger side I needed several long ratchet extensions to reach down to the two bracket bolts from above the engine compartment. Also be careful threading in the new bolts, I think I cross-threaded one of them.
  • Like
Reactions: Fjc
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
I had my Ford dealer install the PP front sway bar for $200.
A buddy and myself did the rear one-much easier.
CVCashmere
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I had a pretty tough time taking the PP front swaybar out on jackstands with a friend’s help. My other friend did the same and said he thought the job was really easy. The drama I ran into was not having the car quite high enough off the ground to get the right angle to get it free and the fact that the PP bar’s bushings come out with the bar. I figure a base front bar would be easier.
The rear is very quick to swap.
  • Like
Reactions: Fjc
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
How long does it take to replace the front sway bar?
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
Bahndvr
Roushcharged
Germany
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
Thanks
Are you missing Germany yet?
Bitte schön, und ja absolut. I miss Bavaria bad...not just because it was ok to drink beer at breakfast, but the feel of the place was unmatched. Of course, driving the autobahns still fills my dreams too. You leave yet or still over there?
Bahndvr
Roushcharged
Germany
I am riding the train for as long as I can.
